OEM lip install ?
Old Mar 30, 2003 | 04:24 PM
UnionCity LS's Avatar
Default OEM lip install ?
when installing the OEM lip is it as easy as 6 screws/bolts? on a 99LS...sorry for not searching...just a yes or no will due..thanks
Old Mar 30, 2003 | 04:30 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: OEM lip install ? (UnionCity LS)
Yes and no. You have the bolts on the bottom and the screws on the side. I just went to a hardware store and got some nuts and bolts. I had the screws from an old project.
Old Mar 30, 2003 | 04:50 PM
Default Re: OEM lip install ? (Gee3)
alright thanks bro
Old Mar 31, 2003 | 09:49 PM
anything else i should look out for when installing?
Old Mar 31, 2003 | 09:54 PM
tC_Dragon's Avatar
um... i think you will need the little clips(wit spot welded nuts) that go on the bottom of ur bumper for hte bolts to screw into... but its a pretty straight forward deal bro.. if you have any experience takin of ur front bumper.. you can do it in under an hr no problem.
Old Mar 31, 2003 | 10:12 PM
Trac226's Avatar
Default Re: OEM lip install ? (pdcdragon)
Very easy install, you might want to try the dealership to get the bottom bolts, but I think bolts/washers from the hardware store will be fine. Two clips on both sides for the screws and your're set! Enjoy your new lip, I sure am.
Old Apr 1, 2003 | 12:39 AM
Integra808's Avatar
Default Re: OEM lip install ? (Trac226)
Well, it's more than 6 bolts/screws. There is 2 screws for the fenderwells on each side...so that's 4 screws. Then 6 bolts for the bottom to hold it to the bumper. 6 bolts/washers and 4 screws total.
Old Apr 1, 2003 | 05:16 AM
2000GSR's Avatar
Default Re: OEM lip install ? (Integra808)
Here you go.
https://honda-tech.com/zerothread?id=411416
Old Apr 1, 2003 | 06:15 AM
Default Re: OEM lip install ? (2000GSR)
thanks to all...and thanks for the thread 2000gsr...
Old Apr 1, 2003 | 08:27 AM
beaterman's Avatar
just put on the two screws on the sides. thats all i have installed on mine and it has held up fine. just becareful when going thru a car wash. and goodluck.
Weifast
12
May 13, 2009 07:17 PM
IntegraLs94Cam
Honda S2000
Mar 19, 2008 06:21 PM
Dave4282
Feb 17, 2006 05:12 PM
Leo C
Feb 9, 2006 02:05 PM
ng
22
Dec 26, 2003 02:53 PM
