compression test, think I Am doing it wrong
1st time I got 160 155 160 170
2nd time I got 180 150 and I didn't bother with the last two.
How come they're different? I read the tutorial from c-speedracing.com but they're not clear on how long should each crank last
also I hear this weird screeching sound, hope that's normal
those are close to my results too... I got 185, 180, 155, and 160 or something like that. Perhaps a bad gauge? Go down to Autozone and borrow one, or if you want I can drop by and test it out with mine since I'm only 10mi or so away. You should crank about 5-7 times, WOT, remove ECU fuse. I think that's it.
it's a brand new one that I got today. since I get different results shoudl I crank it maybe 10 times and maybe about 2 seconds per crank?
I used 5 crank as a standard, but the 2nd clinder will go further if I crank it more. So I should crank until the needle will not move any further? someone confirm this
Yes, crank until it stops moving. It shouldn't require cranking on it for more then 5-10 seconds. Make sure you are constantly cranking, DO NOT crank 1 time, stop then crank agian.
I got 190 180 185 180
I think it's a good thing!!
mach af, that's exactly what I did the 1st time
[Modified by Loveless, 6:24 PM 3/30/2003]
the car has been resting for maybe about 20 min, it's still pretty hot but I'll do it again tommorow. I forgot to step on the gas peddle too
[Modified by Loveless, 6:30 PM 3/30/2003]
the result came back
200 200 190 195
hot engine, throttle open all the way
[Modified by Loveless, 6:49 PM 3/31/2003]
200 200 190 195
it's a good thing according to the test. Are there other things I can check or do to make sure the motor is in top notch spec?
I cranked each cylinder 3 times. each time I wait until I hear 10 cycle (maybe about 5 seconds) until I turn it off. Overkill? Will this cause inaccurate numbers?
JDM_ITR
19
Aug 20, 2003 04:44 PM
