Beaks and BSQ kit and lower tie bar
sorry, archives search is down.
I'm going to get a rear itr sway bar to replace my flimsy gsr's.
Those that have the kits how do you like them?
Did you have to do anything unusual to get the mounts to fit?
Does a lower tie bar in combination with the kit fit? Is it even worth getting a lower tie bar? tia
Beaks 60$ - kit seems a bit beefier/sturdy
BSQ 20$ - price is very appealing
lower tie bar (such as benen) in combination with the rear sway bar - is it going to fit and is this practical for improvement?
tia
tia
Re: Beaks and BSQ kit and lower tie bar (tilt)
i'm gonna go with the beaks kit ragejed also went with beaks. because it is more sturdy and we like to do things right. for those who went with the bsq kit any problems ?
[Modified by RacerXintegra2k, 3:06 PM 3/30/2003]
New User
Re: Beaks and BSQ kit and lower tie bar (RacerXintegra2k)
Re: Beaks and BSQ kit and lower tie bar (Threatcon13)
[Modified by RacerXintegra2k, 3:06 PM 3/30/2003] Are you trying to imply that those who bought the BSQ kit are not "doing things right"?? Bret (bsq) told me that the benen bar fits with his kit w/ no modifcations.
I just like the beaks better. Looks strongs/better to me...but thats my opinion.
Beaks also sells an upgrade kit/longer bolts for tie bars.
[Modified by ragejed, 1:48 PM 3/30/2003]
Re: Beaks and BSQ kit and lower tie bar (ragejed)
i have a beaks kit, i am very pleased with it. it's very sturdy. you do need the tie bar upgrade, if you want to use a lower tie bar.
Re: Beaks and BSQ kit and lower tie bar (DI9ITAL)
I'm using BSQ kit. No problems here. I don't see why people pay $40 more for a kit that 'looks stronger'. I guess beaks makes $40 per kit and bsq makes next to nothing.
Location: Formerly of SF moved to DFW and now back in SF, CA, USA
Re: Beaks and BSQ kit and lower tie bar (MachAF)
I've installed both kits for friends and the Beaks kit is more sturdier by design. But that's because it utilizes a large plate compared to the reinforcement plate of Bret's. It's also more labor intensive. It is a different kit from Bret's (BSQ) and it's a personal choice as to which you like best. Both do the job well and there have been no problems or tearouts with either one.
So what I'm trying to say is, it doesn't matter who's you use. Both work just as good.
Re: Beaks and BSQ kit and lower tie bar (Gatecrasher19AF)
So if you want to use a lower tie bar, you have to get an upgrade kit for both the Beaks and BSQ kit?
Re: Beaks and BSQ kit and lower tie bar (GSRrR)
Here is my Beaks install pics and tips. https://honda-tech.com/zerothread?id=417506
Here is my custom tie bar. The finished pics are at the bottom. https://honda-tech.com/zerothread?id=430148
I'm very happy with the way both turned out.
[Modified by sfr4dr, 4:16 AM 3/31/2003]
Re: Beaks and BSQ kit and lower tie bar (sfr4dr)
Here is my BSQ kit install. https://honda-tech.com/zerothread?id=417506
1 Post
Re: Beaks and BSQ kit and lower tie bar (01SilverGSR)
If you're gonna get a lower tie bar anyways you could order a comptech lower tie bar (just the tiebar from their tiebar/swaybar kit) and mount your ITR sway to it and forget the BSQ or Beaks kit. It's $219US from comptech. It'll be more pricy but in the end I think its a better way to go.
New User
Re: Beaks and BSQ kit and lower tie bar (stumpyf4)
Link!
The following rear lower tie bars work with the Type-R rear swaybar (when used with my BSQ mounting kit) with no further modifications: Spoon, Comptech, JIC Magic and Benen. But there has been a few people that have recently stated that the Benen bar would not fit without some additional spacers. So I'm not sure if Benen has changed their tie bar recently that prevents it from being a direct bolt-on.
Other rear lower tie bars such as the Neuspeed, Skunk2, etc. will work with the Type-R rear swaybar, but you will need a two 1/2" LCA bolts and a two 1/2" spacers which will prevent the tie bar from contacting the swaybar.
Re: Beaks and BSQ kit and lower tie bar (gsr-2nr)
where can u get the beaks kit?
I used this kit on my GSR, works great.
From talking to Wil, the Benen bar will work with the Beaks kit, but you'll need his 'upgrade' kit that consists of longer LCA bolts. Info on the Beaks website.
I have a feeling the sway bar will make a bigger difference than the lower tie bar. those that have a lower tie bar... would you say it's worth it? noticeable improvement? tia
[Modified by sfr4dr, 6:12 PM 3/31/2003]
Re: Beaks and BSQ kit and lower tie bar (TEAM JSJ)
BSQ kit, its nice, cheap, he sends it fast and if you're really cheap he even tells you how to make one of your own.
