O2 Sensor Problems
Old Apr 19, 2004 | 12:39 PM
bboynekro's Avatar
Default O2 Sensor Problems
I've changed out both my o2 sensors twice already primary and secondary and THEY KEEP BLOWING, what the hell is going on here? its getting very very very annoying
Mike
Old Apr 20, 2004 | 03:48 AM
JimBlake's Avatar
Default Re: O2 Sensor Problems (bboynekro)
How about some more detail? What year/engine? HOW do they blow? Does the sensor signal disappear? Does the preheater go open or short? Usually the sensor's signal gets sluggish with age, but I don't know if that's what you mean by 'blowing'.
Old Apr 20, 2004 | 10:11 AM
bboynekro's Avatar
its a 98 gsr, well basicly, last week I changed out the sensor because it was throwing code, so after I swapped it, it went out again, started throwin the same code again, after that it it went out again, and I odn't really understand why
Old Apr 20, 2004 | 10:15 AM
JimBlake's Avatar
Default Re: (bboynekro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboynekro &raquo;</TD></TR><TR><TD CLASS="quote">its a 98 gsr, well basicly, last week I changed out the sensor because it was throwing code, so after I swapped it, it went out again, started throwin the same code again, after that it it went out again, and I odn't really understand why</TD></TR></TABLE>What code was it throwing? After changing the sensor is it still throwing the same code?
Old Apr 20, 2004 | 02:58 PM
blueeg's Avatar
Default Re: (JimBlake)
did u test the sensors? did u check the voltage and reaction time of the sensor? if you changed the sensor twice and it still didnt solve the problem then it probably ISNT the sensor. look for the problem elsewhere.
importnoodles
Mar 29, 2008 10:20 AM
slim689
Apr 19, 2007 10:55 AM
EGY8
Jul 27, 2006 12:49 PM
Lewie
Jun 30, 2004 11:33 AM
