need help with ground control coilover!
Old Apr 18, 2004 | 03:51 PM
SOHCVTECx2's Avatar
Default need help with ground control coilover!
I was able to get the front ones on, but, my problem is with the rear. The rear coilover (coil) doesn't seem to sit on top of the shock properly. DO you guys think i'm missing anything so that the coil would fit on top of the shock, or am i just trippin. If you guys have any pics on how coilovers should fit on the rear, please link me. Or just a simple reply would be fine.
Old Apr 19, 2004 | 07:30 AM
SIK IN DA HED's Avatar
New User
that usually happens. just fit it in as much as you can and bolt it on from there.
Old Apr 19, 2004 | 10:51 AM
HondaDriver85's Avatar
Default Re: (SIK IN DA HED)
Did you use the right rubber rings?? Mine came with 2 different types of rings that u slide the adjustable part over. It tells you which ones should be used with which shocks.
JCushing
Suspension & Brakes
23
Mar 17, 2009 07:03 PM
Samuels
Feb 15, 2008 08:52 PM
BlkslowCRX
Sep 2, 2006 04:21 PM
PA MATT
Suspension & Brakes
Apr 21, 2005 05:32 PM
justininhifi
Apr 30, 2003 12:25 AM
