An odd problem with my teg
Old Apr 20, 2004 | 04:54 AM
gh0st32's Avatar
Default An odd problem with my teg
Ok here is the deal my car will not start up regularly. It will turn over once and not run right for about 30 seconds then idle down and work fine. When I go to start it again it will not turn over it will sputter then die. I had this looked at a month ago and it was supposed to be fixed. Well that didn't work I am assuming it has something to do with either the grounds or the ignition coil.
Has anyone had a a problem like this before? If so what was it?
Thanks
Old Apr 20, 2004 | 07:11 AM
FlaN.'s Avatar
sounds like you need a good tune up to me. you also might want to clean your injectors
Old Apr 20, 2004 | 09:44 PM
gh0st32's Avatar
Default Re: (FlaN.)
Thanks
I replaced everything I am up on the maintence on the car and I clean my injectors every time I change the oil.
Old Apr 21, 2004 | 08:47 AM
Ryan3933's Avatar
Default Re: An odd problem with my teg (gh0st32)
what year teg and how many miles?
92b20teg
Sep 11, 2009 07:26 PM
IntegraGSR311
Sep 14, 2006 08:46 PM
sirtypesh
Apr 1, 2006 12:37 AM
TEG777
Sep 22, 2005 04:47 AM
