battery light on
Old Apr 19, 2004 | 02:19 PM
redlinetuning's Avatar
Default battery light on
Okay, before i start, here's the schpeel.
92 B18A block
94 GSR head
Skunk2 intake manifold
92 Integra GS chassis.
The problem is that the battery light stays on. A new alternator was put in, and so was a new battery. The wiring has been checked over and over. The grounding point surfaces have been grinded down and cleaned to the bare metal.
Any help is appreciated. TIA.
Old Apr 19, 2004 | 02:24 PM
GG-SquadDB's Avatar
Default Re: battery light on (redlinetuning)
reset ur ecu
Old Apr 19, 2004 | 02:26 PM
Default Re: battery light on (96 Ls lnTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 Ls lnTeG &raquo;</TD></TR><TR><TD CLASS="quote">brake switch
what does the brake switch have anything to do with the BATTERY light?
Default Re: battery light on (GG-SquadDB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GG-SquadDB &raquo;</TD></TR><TR><TD CLASS="quote">reset ur ecu</TD></TR></TABLE>
i guess it wouldn't hurt to try.. any other suggestions?
Old Apr 19, 2004 | 02:45 PM
xplanetearth420x's Avatar
ya just reset your ecu it would probly go off
Old Apr 19, 2004 | 03:47 PM
Default Re: battery light on (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">ya just reset your ecu it would probly go off</TD></TR></TABLE>
well.. anyone else know for sure what the problem would be? the alternator's been tested good, ( hence, brand new ).. and so is the battery..
I guess i don't understand what the ECU reset could do for the battery light. i emailed my brother to try it, so i guess i'll wait for more replies, and wait to see what he gets after resetting the ecu.
Old Apr 19, 2004 | 04:08 PM
https://honda-tech.com/zerothread?id=838322
yeah forgot to mention.. code 20 is popping too.. electrical load sensor.. what's that? how to fix?
Old Apr 19, 2004 | 04:47 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinetuning &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=838322
yeah forgot to mention.. code 20 is popping too.. electrical load sensor.. what's that? how to fix?</TD></TR></TABLE>
it's usually directly under the underhood fuse box. it's like any other fuse but more important and it prevents the eletrical system from getting a major surge of eletricity into the ecu(kinda like a surge protector for a computer)
sounds like you "might" of blown this fuse.
get a helms, much more helpful: http://www.helminc.com
Old Apr 20, 2004 | 04:08 AM
JimBlake's Avatar
Default Re: battery light on (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">it's usually directly under the underhood fuse box. it's like any other fuse but more important and it prevents the eletrical system from getting a major surge of eletricity into the ecu(kinda like a surge protector for a computer)
get a helms, much more helpful: http://www.helminc.com</TD></TR></TABLE>What? The ELD isn't a fuse. It's a current-measuring shunt, so your ECU 'knows' the electrical load that's being drawn from the alternator. It uses this to anticipate what it needs to do with the IAC valve to hold a steady idle. Maybe it also uses it to help control the excitation current to the alternator.
Old Apr 20, 2004 | 08:11 AM
no.. resetting the ecu did not fix the problem. My brother said that was one of the first things he did after the alternator and battery was swapped.
Code 20.. any other suggestions? I'll have to find an online Helms to find out what this is.
Old Apr 20, 2004 | 10:05 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinetuning &raquo;</TD></TR><TR><TD CLASS="quote">Code 20.. any other suggestions? I'll have to find an online Helms to find out what this is.</TD></TR></TABLE>Code 20 IS the ELD. It's a current-measuring device that's built into the under-hood fuse box.
Old Apr 21, 2004 | 12:40 PM
Default Re: battery light on (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Code 20 IS the ELD. It's a current-measuring device that's built into the under-hood fuse box.
ok.. i know it's an electric load detector.. i know where it is.. but i don't have the car to look at.. so i'll have to go down to wis.. and i'll get back on this post.. thanks for all the help.
Old Apr 21, 2004 | 12:42 PM
Audi A4's Avatar
HOPE thats not the case...... thoses can be exspensive
Old Apr 21, 2004 | 02:11 PM
AzG35's Avatar
Default Re: battery light on (DRAG lll INTEGRA)
Check all the underhood fuses. I remember reading an old post that if a certain fuse is blown, the ELD code will be thrown and the battery light will come on.
Old Apr 27, 2004 | 08:29 AM
hey guys.. i looked all over for the ELD on the teg.. nothing.. it's not under the fuse box.. it's gotta be somewhere else.. the fuses are fine..
help?
anyone have access to a helm's and can scan it in?
Old Apr 27, 2004 | 08:38 AM
Charlie Moua's Avatar
ok code 20 is eld.
I had a very similar issue with that code as well. It turnd out to my a simple blown fuse (under the steering wheel) It was like some sort of battery fuse there. Check that out 1st!
don't try looking for the actual ELD cause I did and it didn't do anything. ELD is located inside the fuse box (in the engine bay). Its actaully UNDEReith the fuse box. if that makes any sense.
get back to us.
is that the only CEL on?
Also does the car drive fine?..... any issues with charging system or drivablitiy?
Old Apr 28, 2004 | 03:00 PM
Default Re: battery light on (Charlie Moua)
I checked UNDER the fuse box.. but there's nothing (ELD) there.. ?? am I stupid?? haha.. don't answer that last question.. I'll keep looking..
Old Apr 28, 2004 | 03:39 PM
JimBlake's Avatar
I haven't had to take mine out, but I always thought it was built into the fusebox. Not exactly underneath it.
Old May 2, 2004 | 07:19 AM
johannw's Avatar
Same problem in my 89 Prelude. New batt., alt. reset ECU, checked some fuses and the light is still on. I have two Helms just not this car.
Old May 2, 2004 | 09:35 AM
Ls-Rturbo's Avatar
I got the same problem when im sometimes driving the battery light will flicker on and off??? I also got no check engine lights
my bad on jacking the thread
edit: this is on a obd2 2001 typeR actually my friends car but he dont know how to fix ****
Old May 2, 2004 | 10:03 AM
BlackThorN's Avatar
Default Re: battery light on (johannw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johannw &raquo;</TD></TR><TR><TD CLASS="quote">Same problem in my 89 Prelude. New batt., alt. reset ECU, checked some fuses and the light is still on. I have two Helms just not this car. </TD></TR></TABLE>
you have 2 helms just not for this car....how does that help him in the least?
btw if you look at the ELD does it have his own fuse..is there any reason to check it out at all, or should that be the last place he looks after checkin all the various fuses you all suggested he check
Nick
Old May 2, 2004 | 12:54 PM
johannw's Avatar
Default Re: battery light on (BlackThorN)
Well everybody always says get one. One that I have is for an 88 Civic so it is very close in wiring. All fuses are fine also.
Old May 2, 2004 | 12:55 PM
BlackThorN's Avatar
they are the bible, dont get me wrong, I just didn't understand how that helped him
peace
Old May 4, 2004 | 09:46 AM
Default Re: (BlackThorN)
thanks guys.. i'm going home this weekend so i'll take a look at it and come back with soemthing to show with my new fuji.
C5teg
Honda Civic (2001 - 2005)
14
Oct 25, 2007 08:32 PM
924doorEG
Sep 21, 2007 06:09 AM
EG6[B16A1]
Feb 17, 2005 10:52 PM
_bB
Jun 11, 2004 06:53 PM
iridebiketrials
Feb 16, 2004 03:01 PM
