b16a2 head, help please
Old Apr 19, 2004 | 09:51 PM
oMek's Avatar
Default b16a2 head, help please
i just bought a b16a2 head for my new b20 project. this is my first motor build and im gona be learning alot on the way. the head has a cracked valve and there is this brown stuff on the rocker arms.
is that brown stuff a problem?
Old Apr 19, 2004 | 10:02 PM
Sack Master's Avatar
Default Re: b16a2 head, help please (oMekoneDC2)
Brown stuff? What kind of brown stuff? Is it discoloration from running hot or maybe old oil? Maybe sludge build up? Tell us what kind of brown stuff.
If you are building an engine you should take that head to a machine shop. Have them clean it, surface it, and check it. They will tell you if this "brown stuff" will pose a problem.
Old Apr 19, 2004 | 10:13 PM
oMek's Avatar
Default Re: b16a2 head, help please (Sack Master)
sorry the pics are down right now, it looks like scorch marks or something on the rocker arms
Old Apr 19, 2004 | 10:16 PM
Well still take it to a shop and have it checked out. If it got really hot there maybe more problems then a discolored rocker.
Old Apr 19, 2004 | 10:17 PM
thaiphob's Avatar
Nikon!!!
might be extream heat form running really hot oil. if your sending your head for some work the machine shop might be able to give you more help on it. cant really help until the pics come up.
Old Apr 20, 2004 | 11:53 AM
oMek's Avatar
Default Re: b16a2 head, help please (thaiphob)
ok boys, pics are back up. what do you guys think about that brown stuff?
Old Apr 20, 2004 | 11:59 AM
Those rockers look like either not enough oil or the valve lash was way too close. Looks like some major friction issues were going on with that one and your valve train should be checked. I'm sure they are really worn down. I would say the rockers need to be replaced.
Old Apr 20, 2004 | 01:49 PM
oMek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Those rockers look like either not enough oil or the valve lash was way too close. Looks like some major friction issues were going on with that one and your valve train should be checked. I'm sure they are really worn down. I would say the rockers need to be replaced.</TD></TR></TABLE>
im planing on getting the m24x cams and valve train from rocket, i also have new ITR LMA. do you think i really need new rocker arms? i looked at honda and they are like 130$ each. i tryed to clean the brown stuff off with some petrol and it didnt work. when i rub my finger on it i can feel where the cam was and its all smothe and as soon as i hit brown it all ruff.
Old Apr 20, 2004 | 08:57 PM
Sorry I actually meant the tappets need to be replaced. If everything got way too hot then it will be weaker than before. Sounds like you are changing everything over anyways. So no biggie. It's just always a good idea to have anything you are re-using checked out by a good machine shop.
Old Apr 20, 2004 | 11:26 PM
riceball777's Avatar
just take it to a machine shop to have it checked out and have the valve replaced
Hdeucedeuce
Aug 26, 2011 06:05 PM
Propulsion
Northern California (Sales)
Aug 4, 2007 03:04 PM
saintspall
30
Feb 8, 2007 08:47 PM
navin
154
Nov 14, 2003 06:38 AM
Thudpucker
May 27, 2002 07:51 PM
