VALVE TRAIN
Old Apr 21, 2004 | 09:03 AM
JAYGSR's Avatar
Default VALVE TRAIN
ARE VALVE SPRING REALLY AN ISSUE WHEN UPGRADING CAMS ON B18C1 MOTORS OR CAN YOU LEAVE STOCK. ESPECIALY WHEN STOCK REV LIMTITER STAYS THE SAME?????
Old Apr 21, 2004 | 09:18 AM
Audi A4's Avatar
Default Re: VALVE TRAIN (JAYGSR)
Depends on the cams u use..
Old Apr 21, 2004 | 09:35 AM
Havokmkr's Avatar
Default Re: VALVE TRAIN (DRAG lll INTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">Depends on the cams u use.. </TD></TR></TABLE>
Exactly. Most companies will let you know if you need to upgrade the valve springs. Higher lift, longer duration cams usually require upgraded valve springs because you are putting more stress on the stock springs than was intended. Look at it this way, it can't hurt.
B16a2Em1
Mar 30, 2013 01:52 PM
Home Wrecker
Aug 18, 2006 05:50 AM
redlseg
Jun 27, 2005 06:53 AM
dc5r2002
Jun 16, 2004 03:41 AM
