car problem, stalling sometimes
Old Apr 18, 2004 | 04:46 PM
jlv55's Avatar
Default car problem, stalling sometimes
my younger brothers 90 integra is havin starting problems. sometimes after its just been running, it will start up, but then just die out. if it sits for a few minutes it will usually start and run good. could this just be the fuel filter? it was recently replaced. any advice is appreciated.
Old Apr 18, 2004 | 06:27 PM
rated_r's Avatar
Default Re: car problem, stalling sometimes (middleman)
could be a crank sensor
Old Apr 18, 2004 | 07:03 PM
jlv55's Avatar
Default Re: car problem, stalling sometimes (rated_r)
where is the crank sensor and what does it do? why would it only stall if it had just been running, but letting it sit helps?
Old Apr 26, 2004 | 10:30 AM
jlv55's Avatar
Default Re: car problem, stalling sometimes (klutch44)
can someone elaborate? when the car is in neutral or reverse, the RPMs are fine, but once its in drive, sometimes the RPMs drop so low that the car stalls.
Old Apr 26, 2004 | 11:14 AM
Ryan3933's Avatar
How many miles are on the car? Try changing the main fuel relay ($75 new or almost free if you re-solder the old one yourself)
My car would do the exact same thing, and things got worse in hot weather in between warm starts.
Old Apr 26, 2004 | 11:19 AM
jlv55's Avatar
Default Re: car problem, stalling sometimes (Ryan3933)
thats the relay in the fuse box under the hood right? what do i have to resolder?
around 150k on the car.
Old Apr 26, 2004 | 12:52 PM
Ryan3933's Avatar
It's actually under the steering column, real easy to fix or change. Just do a search for main fuel relay. Good luck.
Old Apr 26, 2004 | 07:01 PM
jlv55's Avatar
im having problems locating the relay. what color is it? (90 integra remember)
Old Apr 28, 2004 | 09:59 AM
jlv55's Avatar
??? a picture maybe?
Old Apr 28, 2004 | 10:04 AM
spark plugs.
Guest
Posts: n/a
okay...main thing...i think the question's a bit too vague and there isn't enough detail.
Here's my 2 cents...check the vacuum.
Old Apr 28, 2004 | 10:49 AM
jlv55's Avatar
Default Re: car problem, stalling sometimes (troublecodes)
i really think its the fuel pump relay. i just cant find it.
Old Apr 28, 2004 | 11:08 AM
slomofo's Avatar
GDD Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klutch44 &raquo;</TD></TR><TR><TD CLASS="quote">im having problems locating the relay. what color is it? (90 integra remember)</TD></TR></TABLE>
It's gray with a 10mm bolt holding it down.... I doubt that's the problem though.
Old Apr 28, 2004 | 02:38 PM
jlv55's Avatar
Default Re: car problem, stalling sometimes (slomofo)
why do you doubt its the problem? everyone is telling me to check it and this relay has caused problems for alot of people.
Old Apr 28, 2004 | 04:12 PM
jlv55's Avatar
heres a picture, someone point out where this fuel relay is.
Old Apr 28, 2004 | 04:27 PM
projectTeG's Avatar
its the balck box that has the green writing on it....and it has a big white pug on it
Old Apr 28, 2004 | 04:54 PM
importdude2000's Avatar
Default Re: (projectTeG)
wrong!that is blinker relay the main RELAY IS RIGHT BEHIND IT THE BROWN ONE
Old Apr 28, 2004 | 05:48 PM
projectTeG's Avatar
Default Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">wrong!that is blinker relay the main RELAY IS RIGHT BEHIND IT THE BROWN ONE</TD></TR></TABLE>
oops......lol...i forgot about that. sry for misinforming you , .lol....open mouth insert foot
Old Apr 28, 2004 | 06:03 PM
jlv55's Avatar
thanks. i was looking for a grey one.
Old Apr 30, 2004 | 08:24 AM
Ryan3933's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by troublecodes &raquo;</TD></TR><TR><TD CLASS="quote">okay...main thing...i think the question's a bit too vague and there isn't enough detail.
Here's my 2 cents...check the vacuum.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">It's gray with a 10mm bolt holding it down.... I doubt that's the problem though.</TD></TR></TABLE>
Not enought detail? 1990, 150,000 miles, runs good but hard to start when warm/hot. What more detail do you need? Here's my 2 cents ... it's not a vacuum line. If it was, the car wouldn't run well after starting.
Slomofo, you say you doubt that the MFR is the problem. But you don't suggest any other possibilities.
Frankly, I'm surprised that the MFR lasted this long before failing. If the problem persists after replacing it, your igniter could be the problem.
Old Apr 30, 2004 | 12:00 PM
jlv55's Avatar
well, today it is really really hot. he came home from school while i was working on my car, and it was running fine. he shut it off, and came back to it after a short period of time, and it wouldnt start. i took out the MFR, took it apart to look at the soldering, and it looked fine so i gave it back to him and told him to try it again. the car started fine.
could the reason it started be because i took the relay into my house and let it cool down? it didnt do anything else to it.
Old Apr 30, 2004 | 12:16 PM
MightyMouseTech's Avatar
It is probably the main relay, they usually stick open when hot. If you tap them with a hammer it will usually unstick it and allow it too work. You can usually just bang on the dash to get them to work as well. (if you know where to hit it ) Letting them cool down will also help them. As for resoldering them, I have never seen a main relay with a cold solder problem, it is usually the contacts on the mechanical portion of the relay itself, no chance of fixing those.
One poster mentioned the crank sensor (?) a 1990 Integra does not have any senors on the crank so I REALLY doubt that is the problem
Old Apr 30, 2004 | 01:51 PM
jlv55's Avatar
Default Re: car problem, stalling sometimes (MightyMouseTech)
yeah, the solder looked fine. im just gonna grab one from another integra and see it solves the problem.
LittlesilverEF
19
Feb 20, 2010 02:19 AM
roflcopterdown
Apr 16, 2008 02:15 PM
champLSinteg
Jan 23, 2008 10:56 AM
ShortyzKustomz
Dec 27, 2007 07:10 PM
xiong28
Nov 24, 2007 07:12 PM
