LS/VTEC
Old Apr 18, 2004 | 05:01 PM
jdmteg96's Avatar
Default LS/VTEC
I have a 1996 4 door integra. If i wanted to go ls/vtec would it be better for me to go with the gsr head or a type r head. I am also looking to add on a drag three kit before too much longer. Any suggestions on which head or even which turbo would be nice.
Old Apr 19, 2004 | 07:30 AM
SIK IN DA HED's Avatar
New User
if you're goin turbo soon, stick to the stock LS block.
you would want to use a b16 head if going lsvtec
Old Apr 19, 2004 | 08:02 AM
mystikteg92's Avatar
Default Re: (SIK IN DA HED)
do some research, there are sooo many topics on ls/vtec... u should definately go with a b16 head tho... obviously make sure u do it right otherwise when you put ur kit on.. boom; nobody wants taht, good luck man
Old Apr 19, 2004 | 08:13 AM
Anthrax-VX's Avatar
Default Re: (mystikteg92)
if u want to do ls vtec and still have turbo later , between the two heads the type r head has lower compression than the gsr head and would be better - but if u want to boost alot (nething over 10) u wanna go with a lower compression ratio so it wont detonate - something like an ls head - u can spend that money that u want to spend on a vtec head and just get ur head redone with valve job etc.
Old Apr 19, 2004 | 09:24 AM
dustrag's Avatar
build your block and sleeve it for more boost and run any head you want reasearch a little then decide.. b/c if you rebuilt your lower end then you can run lower comp pistons and then if you feel or just find a gsr head cheaper then it won't matter as much !
Old May 2, 2004 | 01:13 PM
jdmteg96's Avatar
Default Re: LS/VTEC (jdmteg96)
does anybody have a complete gsr or type r head for sale?
Old May 2, 2004 | 03:36 PM
howser111's Avatar
you should just save the money ur planning on investing in the lsvtec and resleeve ur block, get pistons and rods..
but up to you.. i also think an lsvtec/turbo is very unique
Old May 2, 2004 | 04:16 PM
jdmteg96's Avatar
Default Re: LS/VTEC (howser111)
i plan on getting the block built. i am looking at je pistons with eagle rods. i also am going to use darton sleeves. my plan is to bore out the pistons so that i'll have 9:1 compression...does that sound good???
Old May 3, 2004 | 12:43 PM
Anthrax-VX's Avatar
how long does it take to become a member? i should be a member by now so i can post in classifieds
Old May 3, 2004 | 06:20 PM
jdmteg96's Avatar
Default Re: LS/VTEC (Anthrax-VX)
same here man...this not being able to post in the classifieds and other sections doesn't work out for me at all...
Old May 11, 2004 | 04:28 PM
jdmteg96's Avatar
what else would i need to buy in order to go ls/vtec...
head, intake manifold, oil lines, and what else???
Old May 11, 2004 | 05:04 PM
LsV's Avatar
LsV
vtec water pump, vtec oil pump, you can search and find all the info you need. http://hondaswap.com , also another good thing to look into is the golden eagle ls vtec conversion kit.
*EDIT* here are some more helpful sites, http://hybrid2.honda-perf.org/....html, http://www.diyracing.com/ls_vtechowto.html, http://www.angelfire.com/dc/lsvtec/2019.html, golden eagle ls v conversion kit http://www.modacar.com/product...DAENK, honda-tech thread about GE lsvtec conv: https://honda-tech.com/zerothread?id=784891 (My first post)
hatchyAllday
Feb 27, 2008 04:02 AM
Cyphear
May 3, 2007 09:35 PM
hybridb18
Sep 1, 2003 11:07 AM
coldfiremx
Mar 11, 2003 04:36 PM
HarryB
Jul 2, 2002 10:36 AM
