JRSC intercooler
Old Apr 20, 2004 | 12:25 PM
Scharged00GsR's Avatar
Default JRSC intercooler
im ruuning a jackson on my 00 gsr. what i herd was that i could get an intercooler for my setup?
Old Apr 20, 2004 | 12:31 PM
Atheist's Avatar
http://www.lhtperformance.net/products.html
Old Apr 20, 2004 | 04:57 PM
deepgreengsr's Avatar
Default Re: (Atheist)
use water/alch injection wayyyy cheeper and as effective. you can build your own unit for about 30 bucks and an afternoon.
Old Apr 24, 2004 | 07:01 PM
diulay_pkjai's Avatar
Default Re: (deepgreengsr)
Is it true that the JRSC's have a special WI port? Or do I have to inject before the s/c like the Pontiac people?
Old Apr 26, 2004 | 07:30 AM
DC2Slow's Avatar
Default Re: JRSC intercooler (Scharged00GsR)
i wanna put a SC on my 00GSR also what mods do u have and how does the car perform compared to before the mod? thanks
Old Apr 26, 2004 | 05:42 PM
Default Re: JRSC intercooler (DC2Slow)
if you inject it before the throttle body the SC will be more efficient. the water/alc mix will seal the blades just a little better. and provide cooling directly on them. heat soak gone.
Old Apr 28, 2004 | 09:13 PM
you know i was just read up on the wedsite you gave me and i read that it has a 1.5 psi drop. now does that mean if im running 11 psi it will go down to 9.5?
Old Apr 30, 2004 | 02:09 PM
Default Re: (Scharged00GsR)
ttt
Old Apr 30, 2004 | 02:49 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scharged00GsR &raquo;</TD></TR><TR><TD CLASS="quote">you know i was just read up on the wedsite you gave me and i read that it has a 1.5 psi drop. now does that mean if im running 11 psi it will go down to 9.5?</TD></TR></TABLE>
If it works the same way as intercoolers do on a turbo setup, then yes. There is a pressure drop across the field of the intercooler and you lose a little boost. But remember, the air is cooler, and more dense. You will get more power with the same boost level. That 1.5psi drop probably won't feel like anything, in fact, you might gain some power....you probably will.
Ask in the Forced Induction forum to be sure.
Roky
Jan 2, 2005 07:25 PM
keithdphan
Oct 17, 2003 06:47 PM
jbbauer7
Sep 29, 2003 06:12 AM
92TEGsrSC
May 7, 2003 11:15 AM
