210hp
Old Apr 20, 2004 | 10:35 AM
heroinbobaa's Avatar
Default 210hp
i want to get my integra to 210hp if i put a exhaust header intake manifold pulleys cat intake cams and cam gears will the hp be around 210. if not what does anyone sugest to do to get it to that.
Old Apr 20, 2004 | 10:37 AM
Audi A4's Avatar
Default Re: 210hp (heroinbobaa)
UMM no... and wht motor do u have?
Old Apr 20, 2004 | 10:40 AM
95integraLS's Avatar
Default Re: 210hp (DRAG lll INTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">UMM no...</TD></TR></TABLE>
lmfao!
Old Apr 20, 2004 | 10:42 AM
Audi A4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">UMM no... and wht motor do u have?</TD></TR></TABLE>
also i would suggest boost.... but u better have a good job.
Old Apr 20, 2004 | 10:47 AM
JDM_Risa's Avatar
also i would suggest boost.... but u better have a good job.</TD></TR></TABLE>
fosho hp goals are easily achieved in boosted cars
Old Apr 20, 2004 | 10:50 AM
aznxenon's Avatar
If you have an LS, add a bottle of 75 shot and you'll have 140+75 hp!
Old Apr 20, 2004 | 11:01 AM
quikB18B's Avatar
Default Re: (aznxenon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznxenon &raquo;</TD></TR><TR><TD CLASS="quote">If you have an LS, add a bottle of 75 shot and you'll have 140+75 hp!</TD></TR></TABLE>
Yeah and then you get get some pullies 8hp, and 15hp from an exhuast, 12hp from that Dc header y0, wait never mind let me put up my Rice calculator
No offense to original poster, but this is why I hate when Companies, or Superstreet overexagerate, they have half of the poeple beleiveing that a few bolt ons is worth 50hp, while the others are like
On a serious note, yes you can make good power all motor, ut it requires the rihgt parts, generally these are more expensive $$$ than you average I/h/e package, also you need cams, head work, high compression, tuning ect...
Old Apr 20, 2004 | 11:16 AM
turbotommy's Avatar
Default Re: (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">
hahahaha this foo's extra right!
i have full jdm itr internals, 01' jdm itr cams & valvetrain, dc 4-1 ss, ported skunk2 im, injectors, obd2-obd1 conversion, PYR ecu w/ mugen chip, apexi vafc on a 98' b18c1..the compression's at 11.2:1...i could tag 9600rpms and still not pull 210 WHEELhp....wait i havent dyno'd yet
and dont forget the stickers...ahhh da powa of jdm sticka
Old Apr 20, 2004 | 11:19 AM
riceball777's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heroinbobaa &raquo;</TD></TR><TR><TD CLASS="quote">i want to get my integra to 210hp if i put a exhaust header intake manifold pulleys cat intake cams and cam gears will the hp be around 210. if not what does anyone sugest to do to get it to that.</TD></TR></TABLE>
you oviously dont know what your talking about
all that mods you have listed will probably give you like 10whp
and if you have a ls that will come out to be about 130whp
and if you have a gsr that will be about 150-160hp
Old Apr 20, 2004 | 11:31 AM
rwaggie's Avatar
And to the sharp point, just putting all that on without a tune, you could lose some major hp, especially on an LS. Take a stock LS tranny throw up cam gears and say the Skunk2 IM and you're more likely to lose power because your powerband just shifted above the design of the tranny and your stock cams can't make any more power. Research and use the search and see what others have done.
Old Apr 20, 2004 | 12:18 PM
Sack Master's Avatar
Default Re: (rwaggie)
My friends hatch a b16, with a gs-r head. 120 shot direct. Intake, header, exhaust ign. All that stuff and he pulled 194 at the wheels on the dyno this past weekend, est. 250 at the crank. Of course the clutch was slipping a bit. But just goes to show thats its not as easy as one would think. ON this RICE CALCULATOR LMAO, he should be at well over 300 at the crank. Of course we already knew that wasn't even close to the truth. Good luck with that though.
Old Apr 20, 2004 | 06:26 PM
guywitaDA's Avatar
He must have a lot of stickers.....
Old Apr 20, 2004 | 07:42 PM
FlaN.'s Avatar
lay off the heroin
Old Apr 20, 2004 | 07:51 PM
W.O.P.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heroinbobaa &raquo;</TD></TR><TR><TD CLASS="quote">i want to get my integra to 210hp if i put a exhaust header intake manifold pulleys cat intake cams and cam gears will the hp be around 210. if not what does anyone sugest to do to get it to that.</TD></TR></TABLE> holy ****
Old Apr 20, 2004 | 08:00 PM
svtec's Avatar
L D E S
**** all that ****, you need to get a tornado air intake booster!!!!!
mad power bro.
Old Apr 20, 2004 | 10:56 PM
xplanetearth420x's Avatar
your joking right
Old Apr 20, 2004 | 11:02 PM
Sylverius's Avatar
Default Re: 210hp (xplanetearth420x)
Ha, rice calculator. That's just funny in so many ways.
- Jim
Old Apr 20, 2004 | 11:05 PM
Smeeg Heed's Avatar
maybe if this was meant for the s2000 forum
Old Apr 21, 2004 | 12:46 AM
LOWNSLOW's Avatar
Boost is your friend! Well maybe not if you think that set up will get you 210 whp. hmmm ok I take it back maybe boost isn't such a good idea. You might break something.
Old Apr 21, 2004 | 01:06 AM
Smeeg Heed's Avatar
Default Re: 210hp (2Slow2Run)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2Slow2Run &raquo;</TD></TR><TR><TD CLASS="quote">
Boost is your friend! Well maybe not if you think that set up will get you 210 whp. hmmm ok I take it back maybe boost isn't such a good idea. You might break something. </TD></TR></TABLE>
shh breaking something = natural selection.
herionbobaa go ahead and turbo the car. 2 bars should be good. stock internals will EASILY handle that.
Old Apr 21, 2004 | 01:11 AM
LOWNSLOW's Avatar
Default Re: 210hp (NS98GSR)
Throw in 200 shots of NaWzz while ur at it.
Old Apr 21, 2004 | 06:48 AM
babes 99 GSR's Avatar
You can get 200whp without boost, but you will have to spend some money...and also, what integra are we talking about?
-Staci
Old Apr 21, 2004 | 07:53 AM
Audi A4's Avatar
Default Re: 210hp (99GSR1980)
i think were done here
Old Apr 21, 2004 | 08:27 AM
2chron4u's Avatar
Default Re: 210hp (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">
you obviously don't know what you're talking about.
He said CAMS, which cams? You don't know.
Lets break it down:
exhaust - 2.5" no cat
header - dc 4-1
intake manifold - skunk2 IM
intake - whatever
cams -crower 404's
cam gears - whatever
that's good for 160whp or more righ there. That's a gain of 40-50whp from an LS. Of course it needs to be tuned, so throw an SAFC in there, and a FPR and you're good to go.
Now higher compression, a ported head, and a raised redline and he's lookin at 170-180whp.
That is somehwhere about 210hp to the flywheel.
Old Apr 21, 2004 | 08:45 AM
3fiddyZ's Avatar
Buy a different Car that comes with 215whp already. Or drop the dough for a turbo, and build up on the engine, itll work itself out in time, Christ i gotta 350, cams cost me about $1500, and the cheapest FI kit is $6400, i already spent to much loot on the car, now i gotta spend almost double to put it where i want it to be at. Doesn't just come overnight. And there ain't enough stickers in the world thas gonna put your teggy at 215 kid, Crack kills braincells, stop doin it.
