transaxle/nut removal problems
Old Apr 21, 2004 | 07:10 PM
mrxracing's Avatar
Default transaxle/nut removal problems
i can't get my transaxle nut off, front left. I tried using a 2' breaker w/ a 2' pipe on it with
225lbs sitting on it. tried heat, pb blast..one quick thing is, it is counter clockwise right?
and do i need that off to pull the axles out of the tranny?
thanks
Old Apr 21, 2004 | 07:19 PM
wreckedmyteg's Avatar
Default Re: transaxle/nut removal problems (mrxracing)
I think it spins off backwards, to keep it from spinning off when the car is moving forward.
Old Apr 21, 2004 | 07:21 PM
mrxracing's Avatar
Default Re: transaxle/nut removal problems (wreckedmyteg)
so it is clockwise?
in the service manual it shows the guy turning it counter?
i might just have to put the wheels on and take it to a shop to use an air gun
but every is all rwady disconnected..
Old Apr 21, 2004 | 07:32 PM
dwnthehatch's Avatar
It's counter clockwise. I broke 2 breaker bars getting mine off. I bought an air impact and it came right off.
Old Apr 21, 2004 | 07:47 PM
Dan GSR's Avatar
Default Re: transaxle/nut removal problems (dwnthehatch)
I don't get how ppl can't get it off
if its installed correctly, then there should be no problem
make sure to torque it properly, and to stake the nut
only time ive had problem with getting that nut off is when someone else cross threaded the nut by using air tools to put it on.
Old Apr 21, 2004 | 07:56 PM
m R g S r's Avatar
Default Re: transaxle/nut removal problems (Dan GSR)
Yea, one of mine came off with almost no effort, and the other came off by using a little jumping force. It was on a 97 gsr btw.
Old Apr 21, 2004 | 08:41 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: transaxle/nut removal problems (m R g S r)
When i changed the axles on my DA, the nuts were on so damn tight. I tried everything! Since my new replacement axles came with new nuts, i just drilled 1 line in the nut and split it, then removed it
JDM_CRX_PLEASE
Dec 22, 2007 09:24 PM
vinuneuro
Jun 9, 2007 02:59 AM
ilu
10
Mar 31, 2007 04:35 PM
ch00dlz
12
Jan 13, 2006 07:18 PM
FUP23
31
Aug 2, 2002 12:20 PM
