Will i ping?
Old Apr 19, 2004 | 10:32 PM
rough_draft's Avatar
Default Will i ping?
Will i ping with b16 pistons ping on premium gas with my 95gsr? How much room do i got? Will i be safe with a spoon head gasket too? Or shoudl i just go OEM? I'm about to buy some b16 pistons and i just want to double check that they wont bump my compressino up too high. Thanks guys
also, what size rings will i need? how wil they mount up to b18 stock rods?? ty
Old Apr 19, 2004 | 11:25 PM
skunk2_GSR's Avatar
Default Re: Will i ping? (rough_draft)
I have b16 pistons in my 95 gsr and dont have a prob I used b16 piston rings and oem head gasket, stock rods if you leave your head alone you should be at about 11.4:1 compression
Old Apr 20, 2004 | 05:45 AM
Default Re: Will i ping? (skunk2_GSR)
nice, aer you tuned or did you just swap em in and go? What is ur set up? Thanks man
Old Apr 20, 2004 | 06:22 AM
patdemps's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rough_draft &raquo;</TD></TR><TR><TD CLASS="quote">nice, aer you tuned or did you just swap em in and go? What is ur set up? Thanks man</TD></TR></TABLE>
He is tuned. But having problems right now. Check out his thread above yours. He went to the dyno and didn't have the numbers he expected. bad day at the dyno its titled.
SkertySkerty
May 20, 2007 01:41 PM
wfocrx
Feb 7, 2007 04:29 PM
ben_eg6
Sep 21, 2006 07:18 AM
ghostskinner
May 29, 2005 04:55 PM
