help! need to replace exhaust fast!
Old Sep 15, 2004 | 07:21 AM
whiteyGSR's Avatar
Default help! need to replace exhaust fast!
running on cracked, broken, and dragging gs-r exhaust, need to replace fast!
assuming i purchase a dc sports jdm 4-1 header, when purchasing a catalytic conveter with 2.5" inlet/outlet and exhaust system to go with it, would I look for a cat and exhaust designed to bolt up to aType-R or a GSR? and is there anything else i need for it?
Old Sep 15, 2004 | 07:25 AM
dFreezy's Avatar
Default Re: help! need to replace exhaust fast! (whiteyGSR)
you still need a gsr exhaust (assuming the cat you get is oem gsr length).
Old Sep 15, 2004 | 07:37 AM
whiteyGSR's Avatar
Default Re: help! need to replace exhaust fast! (dFreezy)
but aren't JDM itr headers a bit shorter than GSR headers?
Old Sep 15, 2004 | 07:51 AM
IN VTEC's Avatar
Longer.
Use Carsound cat part number 94006. It's a 17" long 2.5" IN/OUT cat. I recommend getting one already fitted with flanges from SMSP. I should clarify that the SMSP Carsound 94000-series cats are 17" long after he's put the flanges on.
Then get a 2.5" bolt-on cat-back system from kteller.com.
Modified by IN VTEC at 11:05 AM 9/15/2004
Old Sep 15, 2004 | 07:57 AM
whiteyGSR's Avatar
Default Re: help! need to replace exhaust fast! (IN VTEC)
ok, so i get the carsound cat and the jdm header, and then a system for a gs-r?
Old Sep 15, 2004 | 08:03 AM
IN VTEC's Avatar
I think an ITR or LS system might be easier to fit, but you still might have to have the exhaust shop chop it down anyways. I'd ask kteller8 or SMSP (if you buy the cat from him) about what they think would work first before you decide.
If he can't tell you, then I'd play it safe and get the longer GS-R cat-back, then have the exhaust shop chop it down to length.
Old Sep 16, 2004 | 06:06 AM
whiteyGSR's Avatar
hmm tough decision...
argh..i'll figure it out soon i hope. otherwise i'll just go with (ugh) dc sports header w/ 2" collector.
integra99blue
Jul 10, 2004 10:50 AM
AintegraA
Dec 18, 2003 02:18 PM
OneFastGsr
Sep 1, 2003 10:36 AM
mr2kqql
May 21, 2003 09:01 AM
One Bad GeeSeeR
May 20, 2003 08:54 AM
