Tranny problem?
Old Sep 13, 2004 | 08:22 PM
aznsins88's Avatar
Default Tranny problem?
I dunno wats going on but my car makes this rattle sound whenever i dont have the clutch pressed down, and when i do have it pressed down, its normal...so i need help figuring out wats wrong and how much it would cost to repair it. Thanks in advance!
Old Sep 13, 2004 | 08:27 PM
jaydeemmmm's Avatar
Default Re: Tranny problem? (aznsins88)
Where is the sound coming from and what kind of sound is it making?
Old Sep 13, 2004 | 08:28 PM
aznsins88's Avatar
Default Re: Tranny problem? (jaydeemmmm)
its comes from somewhere near the tranny...and it makes like this rattle snake rattle..sorta lol
Old Sep 13, 2004 | 09:10 PM
Two_K Si's Avatar
More details?? Are you moving? Speed? Car model and mileage?
Old Sep 14, 2004 | 04:31 AM
JimBlake's Avatar
Clutch throw-out bearing or tranny shaft bearing(s). Try these couple things.
Idle in neutral, clutch engaged (that means you're not pressing the pedal).
Just press the clutch pedal down a bit. Does the noise go away? If so it's probably the T-O bearing. Tranny shaft bearing won't get quiet until the clutch is actually disengaged.
Idle in neutral, clutch engaged, making the noise. Disengage the clutch suddenly by very quickly pressing the pedal all the way down. A noisy T-O bearing gets quiet instantly, while the tranny shaft takes a second or 2 before it coasts to a stop.
Old Sep 14, 2004 | 07:15 AM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznsins88 &raquo;</TD></TR><TR><TD CLASS="quote">I dunno wats going on but my car makes this rattle sound whenever i dont have the clutch pressed down, and when i do have it pressed down, its normal...so i need help figuring out wats wrong and how much it would cost to repair it. Thanks in advance!</TD></TR></TABLE>
does the car drive fine?
shift fine?
Old Sep 15, 2004 | 08:30 PM
aznsins88's Avatar
Default Re: Tranny problem? (Dan GSR)
yea the car drives and shifts fine, this is when im moving and not moving, i have a 1994 integra gsr
Old Sep 15, 2004 | 09:14 PM
Dan GSR's Avatar
input shaft bearing for sure
Old Sep 16, 2004 | 02:34 PM
aznsins88's Avatar
how much are those?
Old Sep 16, 2004 | 03:56 PM
Dan GSR's Avatar
bearing is cheap
labor is $$$$$$
the bearing is INSIDE the transmission
Old Sep 17, 2004 | 02:42 PM
aznsins88's Avatar
how long can i go without replacing it?
Vadim_D
Jun 20, 2010 09:02 PM
SpoolnEG6
Aug 16, 2005 02:15 PM
jdmstreethatch
Mar 21, 2004 09:12 AM
Hung
Apr 28, 2002 06:17 AM
91HATCH
11
Jan 14, 2002 06:47 PM
