overheating
Old Sep 14, 2004 | 09:04 AM
zbower7's Avatar
Default overheating
alright first i thought it was my fan well i rigged the fan so it was on a switch and i could run it all the time when the car is turned on, but that didn't stop the problem so then i thought well its gotta be my thermostat so i replaced it. the old one was really hard to move the springs on it they were almost locked up. but i think i need to burp the radiator because i can't get any pressure in my radiator hose. what do i need to do to get pressure in them. and if i get pressure in them and that doesn't keep it from overheating would it be my water pump. i am just lost help me.
Old Sep 14, 2004 | 09:48 AM
psychotic_z's Avatar
Default Re: overheating (zbower7)
What car and how many miles? Water pumps don't fail too often, me thinks. Is there water in your radiator? Check for low water, you might be surprised. You can try flushing your system as well. If something is stuck in the system, that causes an obstruction and that might contribute to overheating.
And when does it overheat? Idle? Hard driving? Long trips? Whenever it feels like it?
If you changed the thermostat and your water's full, then there isn't much place else to look besides the water pump, eh? Check your Helms or other crappy manual to troubleshoot a shitty water pump.
Old Sep 14, 2004 | 10:24 AM
zbower7's Avatar
Default Re: overheating (psychotic_z)
um its s 94 ls built motor with darton sleeves boored to 84 mm. built head. the radiator is a 2 in chore alum. radiator. it over heats when i just drive the thing out of the apartment complex.
Old Sep 14, 2004 | 02:44 PM
Did the builder (or you) replace the water pump when it was built?
If you're not getting pressure in your hoses at all and the thermostat's even been replaced, likely it's the water pump unless you have a serious leak somewhere. No water/coolant in the oil, is there? Head gasket's a possibility. Might try a compression test as well for good measure.
Ryebread1974
Sep 24, 2018 04:24 PM
@imraging
Aug 10, 2014 05:13 PM
xTomei
61
Aug 6, 2010 10:01 AM
MFButler
Mar 11, 2010 11:30 AM
TurboTeG4
12
Dec 27, 2009 10:20 AM
