Need help please, Transmission Problem
Old Sep 14, 2004 | 05:51 PM
Greg James's Avatar
Default Need help please, Transmission Problem
ok, when I push the throttle and then let off, when the rpms lower, there is a rattling noise that sounds like a frog in the transmission... The only think I can think of is the throw out bearing. It threw the engine light this morning and I don't have time to get it checked until Friday so could someone please enlighten me?
Modified by Greg James at 10:25 PM 9/14/2004
Old Sep 14, 2004 | 06:28 PM
Greg James's Avatar
Default Re: Need help please, Transmission Problem (Greg James)
Please, someone
Old Sep 14, 2004 | 06:53 PM
VTECrazed's Avatar
Alright your throw out bearing should make a constant sound if its bad. Not just when rpm's lower. But if your sure its from the transmission than by all means go with that. But I'm just saying your throw out bearing would make noise when its just sitting in idle. it would get louder too as you let out the lcutch and than at the grabbing point it should go away. But at idle is when you should hear the rattling sound from the transmission. If your throw out bearing is really screwed than you would hear it no matter what.
Old Sep 14, 2004 | 07:50 PM
allmotorteg_96's Avatar
Default Re: Need help please, Transmission Problem (VTECrazed)
it could be your release bearing.
Old Sep 15, 2004 | 05:34 PM
Greg James's Avatar
Default Re: Need help please, Transmission Problem (allmotorteg_96)
ok, I took it to Autozone and had them read the code and they said that it had something to do with the emissions, so he popped the hood and found a hole in the 'Emissions Canister,' as he called it, so he put some tar on it to stop the vacuum leak but the light is still on, do you all thin that this is the problem. When I accelerate, it makes the sound of escaping air like on and air compressor when you open the valve. Here is a picture of what he is talking about, whats the correct name of it so I can order it at work?
Old Sep 15, 2004 | 08:33 PM
JohnnyTeg's Avatar
Someone's gotta know whats wrong, same deal with my 95 GSR, when I let the idle run down through ~3500-3100rpms. Its not a loud sound by any means, but annoying when you have to hear it everyday.
og seany b
Jul 17, 2010 07:03 PM
LukieLuc
Jul 3, 2007 04:11 PM
ElectronBlueGsr1.8
Jul 27, 2004 05:24 AM
All_JDM_Si
10
Oct 9, 2003 03:30 AM
