Help!! suspension question
Old Sep 15, 2004 | 07:57 PM
SkinnyKinnee's Avatar
Default Help!! suspension question
ok, im a moron and drilled a curb running from a cop with my lights off. my left front wheel is pushed back and my left rear is cambered in and toed out. so far i know the front lca and the rear uca are bent but im sure ill find more. Anyone had this problem?
i know the rear uca is the same on most civics and tegs but what about the front lower arms? it would make things a lot easier.
Does anyone know of a 90-93 teg thats being parted out?????
anyone have their stock rear arms after camber kits were installed?
thanks!!!!!!
Old Sep 15, 2004 | 08:00 PM
Dan GSR's Avatar
Default Re: Help!! suspension question (SkinnyKinnee)
Old Sep 15, 2004 | 08:18 PM
Kendall's Avatar
I can't say that what you were doing was by any means smart. Check in the classifieds and if that is to no avail, look up Import Auto Salvage in Marion, NC, they should be able to help you get everything you need. Also, make sure you didn't fubar any of your shocks.
Old Sep 16, 2004 | 10:34 PM
integramic's Avatar
I have a front lower but need to know exactly what you need and howmuch you are offering. I have a set but may split.
The front civic's are different. Useless you change stock and everything(it will ride weird also)(because it will not be right).
Old Sep 17, 2004 | 02:16 AM
B18OnTop's Avatar
Default Re: (integramic)
DA9_TypeR
Apr 24, 2006 06:28 AM
drew2
Feb 15, 2006 03:41 PM
Tweakmeister
26
Jan 4, 2005 01:17 PM
crazyass05
Jun 2, 2004 04:31 PM
