Alternator problem???
Old Sep 13, 2004 | 08:20 PM
aznsins88's Avatar
Default Alternator problem???
Yea i dont know if its my alternator or something but my car like turns off automaticallly...all the cables and wires are on tight...battery is good...belts are good...so i really dont know wat is could be wrong besides the alternator...opinions would nice...plz help. Thanks in advance!
Old Sep 13, 2004 | 08:24 PM
jaydeemmmm's Avatar
I assume your car starts up fine? Does all the power items work inside your car? If you have problem starting up your car and the power items don't work, it's probaly your alternator.
Old Sep 13, 2004 | 08:26 PM
aznsins88's Avatar
Default Re: (jaydeemmmm)
well i think all the power stuff inside the car works...its just the car...it just shuts off and when trying to start it sometimes...it doesnt even make that start up noise...its like silent
Old Sep 13, 2004 | 08:34 PM
jaydeemmmm's Avatar
It might be your starter.
Old Sep 13, 2004 | 08:38 PM
aznsins88's Avatar
how much is it to replace starters..o yea btw...the car always idle under 1000rpm...shocks me
Old Sep 13, 2004 | 08:40 PM
jaydeemmmm's Avatar
What's your idle right now? After warmup, I'm at about 800 RPM which is normal.
Old Sep 13, 2004 | 09:13 PM
sabotage7's Avatar
Default Re: Alternator problem??? (aznsins88)
if your battery is good, then your alt is probably good cuz if your alt is bad, your battery usually wouldnt charge up.....did you actually get a load test done on your battery to determine that its good?.....the starter would have nothing to do w/your car cutting off while its running since the starter just starts the car....if the alt is bad however, it could cause the car to shut off bc its not generating power correctly.......maybe one of your wires is corroded, sometimes your wire may look good, but get corroded on the inside in which case all the voltage wouldnt make it thru the wire causing a bad connection.
sheldon911
14
Jun 23, 2009 10:34 PM
SupraRXZ
Mar 20, 2007 07:52 AM
SkyeC
Jan 12, 2004 01:42 PM
bluesaint
Mar 6, 2003 09:38 AM
Fobstylez
Jul 6, 2002 02:11 AM
