bent valves?
Old Sep 16, 2004 | 11:35 AM
bb6h22's Avatar
Default bent valves?
my buddys car: 99' gsr w/cel's= secondary o2 and map sensor
can a having bent valves cause me to not rev passed 6900?
Old Sep 16, 2004 | 11:55 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: bent valves? (bb6h22)
Bent valves would throw codes 71 to 74 for cylinder misfires. Is the VTEC solenoid engaging? (This could cause the rev limit.)
Old Sep 16, 2004 | 12:14 PM
bb6h22's Avatar
Default Re: bent valves? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Bent valves would throw codes 71 to 74 for cylinder misfires. Is the VTEC solenoid engaging? (This could cause the rev limit.)</TD></TR></TABLE>
were gunna go pull the codes today and we'll see, but it sounds like vtec is engaging how is another way you can tell?
Old Sep 16, 2004 | 10:33 PM
bb6h22's Avatar
anybody else?
Old Sep 16, 2004 | 11:36 PM
CRX_1.8T's Avatar
pull the head, then roll the suspect valves on the end of a table to see if they are warped.
that is time consuming, never mind.
Old Sep 17, 2004 | 04:14 AM
Dogginator's Avatar
Daisy... Daisy...
A simple compression check will tell you if you have bent or improperly adjusted valves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6h22 &raquo;</TD></TR><TR><TD CLASS="quote">
were gunna go pull the codes today and we'll see, but it sounds like vtec is engaging how is another way you can tell?</TD></TR></TABLE>
Most people mistake the intake air bypass (IAB) switch at 5700 rpm for the VTEC engagement on a GSR. However, the VTEC crossover occurs near 4400 rpm and is usually inaudible and imperceptible (as it should always be if it is tuned properly) on a stock motor. How does the motor pull and sound as it approaches this 6900 rpm limit?
Old Sep 17, 2004 | 06:48 AM
bb6h22's Avatar
well we pulled the code, and it was only the secondary o2 sensor. that shouldnt keep it from revving passed 6800/6900...
dogginator, the motor pulls hard and strong as it approaches 6900rpm's
Old Sep 17, 2004 | 08:43 AM
Dogginator's Avatar
Daisy... Daisy...
What happens when it hits 6900 RPM? Does it cut-out like a rev limiter or just quit producing enough power to accelerate the motor? It has to do one or the other. Also, does this limit happen the same for all gears?
Old Sep 17, 2004 | 12:46 PM
bb6h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">What happens when it hits 6900 RPM? Does it cut-out like a rev limiter or just quit producing enough power to accelerate the motor? It has to do one or the other. Also, does this limit happen the same for all gears?</TD></TR></TABLE>
it cut's-out like a rev limiter. and yes it does this in 1st and 2nd im pretty sure its the same for every gear
Old Sep 17, 2004 | 01:18 PM
bb6h22's Avatar
Old Sep 17, 2004 | 05:12 PM
bb6h22's Avatar
hmm, cleaned the vtec solenoid and still same problem.
Old Sep 17, 2004 | 07:14 PM
bb6h22's Avatar
help
Old Sep 18, 2004 | 08:13 PM
bb6h22's Avatar
Old Sep 18, 2004 | 09:33 PM
ttercahnncoe's Avatar
Did you do any wiring changes like put in a Vtec controler or something like that???? I ran in to it with my car. I had something wired wrong or backwards and it would only run that high before cutting out. Also try diconnecting the battery for 30 to 50 sec. and connect it again. Try that if check engine light is off and still runs that way then I'm not sure at this point but try that
Old Sep 19, 2004 | 07:52 AM
bb6h22's Avatar
Default Re: (ttercahnncoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ttercahnncoe &raquo;</TD></TR><TR><TD CLASS="quote">Did you do any wiring changes like put in a Vtec controler or something like that???? I ran in to it with my car. I had something wired wrong or backwards and it would only run that high before cutting out. Also try diconnecting the battery for 30 to 50 sec. and connect it again. Try that if check engine light is off and still runs that way then I'm not sure at this point but try that</TD></TR></TABLE>
yeah i used to have a vafc maybe i should check the wires on the ecu. but yeah i tried resetting the ecu and im still getting the CEL
Old Sep 20, 2004 | 06:56 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (bb6h22)
Your ECU may be in a limp mode. But I'm thinking the limp mode limited the rpm to around 4000. Have you verified that the ECU is a P72? The P/N is printed where the wiring harness connects. It should read 37820-P72-A0#.
Old Sep 20, 2004 | 05:36 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Dogginator)
Is an aftermarket ignition with a rev limiter installed on this car?
Old Sep 20, 2004 | 08:25 PM
bb6h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Is an aftermarket ignition with a rev limiter installed on this car?</TD></TR></TABLE>
no its the stock p72 ecu we still cant figure out whats going on
Old Sep 20, 2004 | 10:43 PM
Leftnut's Avatar
i had the same problem with my Gsr and mines was distributor.. it was advanced to much so after that i checked the ignitor too. those two things solved my problem hope it helps you.
cptengineer
Nov 22, 2005 07:33 AM
Boostage
Sep 17, 2005 10:36 PM
lemongreenhatch
Oct 27, 2004 09:28 PM
K-Drum
Sep 27, 2004 10:35 AM
spoon23_JDizM AkA SpOoN20
Sep 9, 2004 06:04 AM
