Vtec question.
Old Aug 29, 2005 | 07:40 PM
Lauj87's Avatar
Default Vtec question.
alright guys i have a question about my vtec... i have a 96 GSR i know vtec engages at 4.4k but is that the same RPM where it switches to the vtec cam lobe?
Old Aug 29, 2005 | 07:48 PM
Mr_CRX's Avatar
Default Re: Vtec question. (Lauj87)
Yes, it switches to the more aggressive cam lobe when VTEC engages.
Old Aug 29, 2005 | 08:56 PM
GsrGilbert's Avatar
Default Re: Vtec question. (Mr_CRX)
yes that would be the wide world of vtec keep in mind u have secondairies which open up later.
Old Aug 29, 2005 | 09:01 PM
sk8phaze's Avatar
Default Re: Vtec question. (GsrGilbert)
I have a 1996 integra with a ls/vtec (using a B16a head) and i run a 1996 GSR (P72) ecu and i feel the vtec kick at 4500rpm, but it seems like it adds more fuel once it hits 5400+rpm, almost like a two stage vtec(which i know its not). anyone have any comments to add to this?
Old Aug 29, 2005 | 09:03 PM
ETA_Si's Avatar
my VTECH kicks in at 5,7000 RPMs haha
Old Aug 29, 2005 | 09:31 PM
Mr_CRX's Avatar
Default Re: Vtec question. (sk8phaze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8phaze &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1996 integra with a ls/vtec (using a B16a head) and i run a 1996 GSR (P72) ecu and i feel the vtec kick at 4500rpm, but it seems like it adds more fuel once it hits 5400+rpm, almost like a two stage vtec(which i know its not). anyone have any comments to add to this?</TD></TR></TABLE>
If you're running a stock ECU (which I'm guessing you are since you said it was a 1996 p72...), the VTEC engagement point is too low for a single-stage intake manifold like those on the B16's and Type-R motors. The P72 is programmed for the dual-stage intake manifold on the GSR (it has secondary butterflies..)
On the stock P72, VTEC is set at like 4400 rpm, and the butterflies are supposed to open at ~5500 or so.. (I forget where, exactly..). When you run the p72 with a single-stage IM, the VTEC point is too low, and will cause it to bog until around 5600 or so like you're feeling, since it has no secondary butterflies to open up. If you have a VAFC or another way of changing the VTEC engagement point, set it up around 5500, and you should feel a lot smoother transition.
Old Aug 29, 2005 | 09:34 PM
sk8phaze's Avatar
Nice, thanks for the quick reply, know anyone that has a APEX-I VAFC-II for sale, for a reasonable price?
Old Aug 29, 2005 | 09:35 PM
sk8phaze's Avatar
BTW sorry Lauj87, im not trying to ***** up your thread!
Old Aug 29, 2005 | 10:11 PM
Lauj87's Avatar
thanks for all the input guys....i was thinging about putting in another chipped p72 vtec engages at 5500 rpms along with the secondaries. i was wondering if the stock setup is better...knowing the GSR needs the torque all the way untill the secondaries.
Old Aug 29, 2005 | 10:23 PM
Mr_CRX's Avatar
Default Re: (Lauj87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the input guys....i was thinging about putting in another chipped p72 vtec engages at 5500 rpms along with the secondaries. i was wondering if the stock setup is better...knowing the GSR needs the torque all the way untill the secondaries.</TD></TR></TABLE>
You don't need to change the VTEC point unless you have changed out the intake manifold to a skunk2/blox or similar, single stage manifold. If you still have the stock GSR manifold with the secondaries, you'd probably be better off leaving the VTEC/secondaries RPM engagement points alone.
Old Aug 29, 2005 | 10:27 PM
LSTEG96's Avatar
Default Re: (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">You don't need to change the VTEC point unless you have changed out the intake manifold to a skunk2/blox or similar, single stage manifold. If you still have the stock GSR manifold with the secondaries, you'd probably be better off leaving the VTEC/secondaries RPM engagement points alone.</TD></TR></TABLE>
hes got a b16 head... so he doesnt have the 2 stage manifold... hes saying its dumping fuel cause the ecu thinks the 2ndaries are there... when they arent.
Old Aug 29, 2005 | 10:49 PM
Mr_CRX's Avatar
Default Re: (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">hes got a b16 head... so he doesnt have the 2 stage manifold... hes saying its dumping fuel cause the ecu thinks the 2ndaries are there... when they arent.</TD></TR></TABLE>
sk8phaze is the one with the b16 head ... The original poster (Lauj87) just said he had a 96 GSR, so that's what I was referring to.
Old Aug 30, 2005 | 09:23 AM
teddy_dc2's Avatar
i though vtec kicks in at 5500? mine does but you can hear it good at ~6000 rpm.
Old Aug 30, 2005 | 09:46 AM
hobo_ken's Avatar
Default Re: (teddy_dc2)
vtec engages at 4400rpm in a B18C. The secondary runners open at ~5800rpm. This may be what you are hearing since you can hardly hear the vtec crossover in a stock car.
J's GS-R
Feb 21, 2006 09:13 PM
msbhvn_DC2
Feb 9, 2006 07:39 AM
zerogravitycrx
43
Jan 15, 2006 05:00 PM
shyboi4u
Oct 7, 2005 11:54 PM
lowridincivic92
Aug 31, 2005 02:24 AM
