acceleration prblem HELp PLEASE
Old Aug 29, 2005 | 01:32 PM
ttaplin's Avatar
Default acceleration prblem HELp PLEASE
my 96 gsr jolts forward in all my gears its not just one jolt it does it several times i dont know what it wrong any ideas
Old Aug 29, 2005 | 02:38 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: acceleration prblem HELp PLEASE (ttaplin)
Important question.....automatic or manual?
Old Aug 29, 2005 | 03:00 PM
Lauj87's Avatar
Default Re: acceleration prblem HELp PLEASE (shamoo)
well its a GSR soo most likely its a manual.....sounds like a timeing problem might be off..my old honda accord did that too...when your in gear and you want to accelerate it chugs first..then it'll start to pick up right?..if it dose that its a timeing problem!
Old Aug 29, 2005 | 03:47 PM
skata89's Avatar
Default Re: acceleration prblem HELp PLEASE (Lauj87)
do you mean by timing like in bad shifting?
Old Aug 29, 2005 | 06:09 PM
Lauj87's Avatar
no timeing as in timeing belt..... might be off causing a misfire.
Old Aug 29, 2005 | 09:29 PM
ttaplin's Avatar
its a manual im having it looked at in the morning tomorrow so i hope its nothin serious cause im selling it
Old Aug 29, 2005 | 11:29 PM
LSTEG96's Avatar
Default Re: (skylinedo)
bad motor mount?
Old Aug 30, 2005 | 05:30 AM
ttaplin's Avatar
it jolts violently and i use 90
Old Aug 30, 2005 | 05:48 PM
Axle's Avatar
Default Re: (ttaplin)
If it is not engine related after they inspect it, it could be a severe case of clutch slip where it engages and loses the grip over and over again. Could also be the input shaft bearing is worn down, but those are more like vibrations and chattering, not really jolting of the entire car.
Old Aug 31, 2005 | 08:21 AM
ttaplin's Avatar
threy said it was my distributor cap and ignitions rotor i had to special order the cap cause i have msd but i put the rotor in it help some
Transmission & Drivetrain
Apr 14, 2010 03:35 PM
Mathias927
Sep 29, 2008 06:53 PM
ashes12
16
Mar 20, 2006 02:36 PM
JDM-EJ1
Feb 28, 2005 08:50 PM
waxbunny
Nov 29, 2004 02:25 PM
