check engine light problem
Old Aug 31, 2005 | 08:13 AM
BAYgasDC2's Avatar
Default check engine light problem
day 1 start the car, check engine light is on/it wants to die then idles at 1500k/wont pass 3100k/bogs and jerks hard/max speed on freeway 61mph at 3100k/ so i disconnect the battery to reset the ecu then its fine
day 2 ok
day 3 same as day one but as i am on the freeway check engine light goes away
day 4 same exact as day one
day two exact as day 3
can anyone tell me the problem?can it be cause of the weather in the bay area?it doesnt go on in the afternoon when the weather heats up tried the paper clip solution..not throwing any codes
if this helps is a 1994 gsr
B&m fpr
blox intake manifold
72/70mm throttle body
jdm itr headers
catco 2.5 piping
es oval catback 2.5
short ram intake
itr lighten flywheel
itr clutch
chipped ecu (race chip)
Old Aug 31, 2005 | 10:22 AM
ecks_fourttwo's Avatar
Default Re: check engine light problem (JDMEKSLEEPER)
might be:
ecu
ignitor
wiring
plus your flywheel probably already gives you a rough idle
just some suggestions...
Old Aug 31, 2005 | 11:21 AM
BAYgasDC2's Avatar
bump thanks for the suggestions
Old Aug 31, 2005 | 02:55 PM
BAYgasDC2's Avatar
thanks bro bumpity bump
Teamdiesel
May 18, 2007 05:57 AM
JDMtype Eg6
Sep 21, 2005 09:26 PM
EVIL TYPE R
Feb 21, 2005 02:31 PM
RAB
Mar 9, 2003 10:00 PM
