oil issues?
Old Aug 30, 2005 | 01:24 AM
tdgcgpgsr's Avatar
Default oil issues?
My stock gsr has 133k miles, i've had her for only 4 months, everything's great. When I bought it, an oil change had just happened...Couple months ago, oil light flickered sometimes going over bumps/ sharp turns etc. so I change the oil and barely a quart came out. So, filled it up, everything's ok.... I check the level periodically, its' fine.
The other day it is so low I can't even see any on the dipstick. I dump a few quarts in there for now... and I don't smell it burning any oil unless I'm just retarded...I' don't know much about cars so this is really a problem.
What do you suggest I have checked out first? It's probably relatively simple.
I am slightly inebriated or was or something so perhaps this is not making all the sense it should but I really need help!
Old Aug 30, 2005 | 02:00 AM
jdm_integratyper's Avatar
Default Re: oil issues? (booshgsr)
probally a leak at the oil pan go get it check out since you dont know much about cars try not to drive it with low oil you will mess up your car
Old Aug 30, 2005 | 05:45 AM
Baron55's Avatar
Are you using vtec a lot?
Old Aug 30, 2005 | 05:49 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: oil issues? (jdm_integratyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_integratyper &raquo;</TD></TR><TR><TD CLASS="quote">probally a leak at the oil pan go get it check out since you dont know much about cars try not to drive it with low oil you will mess up your car </TD></TR></TABLE>
Definitely a leak somewhere. Jack up the car, do you see any leakage? Any oil/crud residue under there? That's a lot of oil to lose in a short amount of time. Something is wrong there. Look at the engine bay too....anything leaking? From the valve cover? Cam seal? Distributor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">Are you using vtec a lot?</TD></TR></TABLE>
Won't make a difference. If the car is working correctly, you can be in Vtec 24 hours a day and you shouldn't be losing that amount of oil.
Old Aug 30, 2005 | 05:58 AM
Baron55's Avatar
my car can lose up to a quart over 7 days if i use a lot of vtec...No smoke and it has no leaks..Someone told me to switch to 10w-40 so it wont comsume that much oil...
Old Aug 30, 2005 | 06:11 AM
Greddy Dantegra's Avatar
how are you driving the car? do you warm up the car? you do know that if you dont warm up the car and just driving it burns oil alot quicker!!!! and if you drive it in the high rpms you burn oil too.... try warming up your car for like 5-10minutes before driving it.... or look on the floor see if your leaking...... or pop open your hood by the valve cover see if you see spots of oil you might need a new gasket!
TinoNT
Apr 26, 2013 01:34 AM
iGGY366
Honda Civic (2001 - 2005)
Dec 6, 2007 02:17 AM
sailor_55
Nov 4, 2007 09:14 PM
chuckus
Oct 22, 2004 02:45 PM
joshalee
Aug 26, 2004 12:04 AM
