integra help?
Old Aug 28, 2005 | 06:19 PM
xintegr's Avatar
Default integra help?
my 98 gsr started leaking engine coolant today. when i open my hood i notice some was on my hood and there was a good amount at the bottom of the coolant bottle. i had a front end accident recently. nothing serious but maybe it was enough to crack something therefore causing the coolant to spill? but the accident was about 1-2 weeks ago and it started leakin today so im not sure its because of that. what do you guys think is makin it leak?
Old Aug 28, 2005 | 06:22 PM
Lauj87's Avatar
yeah its prolly because of that...when you were hit...cracked it a little...then overtime the heat just expanded it to the point of leakage!
Old Aug 28, 2005 | 06:42 PM
xintegr's Avatar
Default Re: (Lauj87)
how do you think i should go about to check where its leaking. take off my bumper?
Old Aug 28, 2005 | 09:49 PM
White cracker yeehaa's Avatar
take of the radiator.....first drain it completely take it off of the car, and then flush it w/ a hose to completely fill it, then plug back the thing to you took out to drain it, and you should see where it is leaking...hope that helps
Kasheena Winn
Oct 28, 2017 03:21 PM
meow27
Feb 3, 2014 06:31 AM
Special_K26
May 6, 2013 05:13 PM
EK_logkomlki
Acura TL, RL & ZDX
34
May 7, 2007 09:50 AM
sagaprelude
Feb 3, 2002 07:45 AM
