o2 Sensor
Old Aug 30, 2005 | 01:28 PM
Iomega01's Avatar
Default o2 Sensor
When replacing a o2 sensor. Do I replace the one before or after the cat? Also how often should it be replaced? Thanks.
Old Aug 30, 2005 | 01:35 PM
txracer's Avatar
Default Re: o2 Sensor (Iomega01)
depends on wich one needs to be replaced, one cost more then the other too. and you need a 02 socket other wise have fun getting it off, and wd40 is your best friend when do you swap them out
Old Aug 30, 2005 | 01:42 PM
Iomega01's Avatar
Default Re: o2 Sensor (txracer)
o2 socket? what does that look like and where can I get one at?
Old Aug 30, 2005 | 01:45 PM
txracer's Avatar
auto parts store, its a like your normal deep well socket but it has a section cut out so you can fit it over the wires, here this might help explain it more. i am also not sure what size you would need
http://www.daemione.com/breaker_bar.JPG
Old Aug 30, 2005 | 02:36 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by txracer &raquo;</TD></TR><TR><TD CLASS="quote">depends on wich one needs to be replaced, one cost more then the other too.</TD></TR></TABLE>
They're interchangeable. The only difference is the wiring (slightly longer and with a rubber grommet), due to the secondary O2's location. Pricing from Acura Automotive Parts is identical for the primary and secondary.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by txracer &raquo;</TD></TR><TR><TD CLASS="quote">you need a 02 socket other wise have fun getting it off, and wd40 is your best friend when do you swap them out</TD></TR></TABLE>
All you need is a 22mm wrench to remove and install the sensor. I'd recommend applying a small amount of anti-seize compound to the threads of the sensor before installing it, to make future remove easier.
SiMateoAko
27
Jun 27, 2005 09:16 PM
LostAndFound
18
Jun 25, 2004 10:46 PM
jentegraGS-R
Apr 2, 2004 02:40 AM
AL ASPIRATED
Nov 11, 2003 10:34 PM
JoshRambo
May 15, 2003 07:16 PM
