Help with fuel problem.
Old Jul 30, 2006 | 10:33 PM
FrOsTwHiTeDC4's Avatar
Default Help with fuel problem.
Okay, this is how the story goes. I was driving down the road and my car just died. I swapped out the dizzy, plugs & wires, main relay, checked all grounds and fuses, swapped ecu's, and none of that seems to work. I seem to think its my fuel pump. My question is since I have an inline fuel pump lying around from my old car is there anyway i could use this to see if it infact is my fuel pump that is causing me problems?
TIA
Albert
PS: I also have an FMU but no FPR.
Old Jul 30, 2006 | 10:36 PM
all-mtr-teg's Avatar
Default Re: Help with fuel problem. (FrOsTwHiTeDC4)
just spray some starting fluid in the throttle body first to see if it cranks over. Thats a lot easier than wiring up an external fuel pump. worked for me.
Old Jul 30, 2006 | 10:41 PM
Twilightepitaph's Avatar
turn the key to the on position and listen to see if you hear the fuel pump priming. If you hear a humming then your pump is working, if you just hear a click under the dash then your pump might be out. If that is the case you might get a voltage checker and make sure the pump is actually getting power before you go and replace it.
Old Jul 30, 2006 | 10:42 PM
Default Re: Help with fuel problem. (Twilightepitaph)
Yea, I do not hear it prime which is why I was wondering if I could do the inline thing.
Old Jul 30, 2006 | 10:47 PM
jdm_bones's Avatar
Check your injectors...
carracr625
Apr 19, 2019 06:29 AM
hatchBK4life
Aug 2, 2010 05:11 PM
nafreak
Mar 21, 2007 07:39 PM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
ill phil
Apr 23, 2003 11:58 PM
