trans to engine bolts?
Old Jul 28, 2006 | 07:12 AM
killerpenguin21's Avatar
Default trans to engine bolts?
ayone know what size they are? or a part number??
the parts guy at my local dealer has no idea what im talking aout when i ask for these bolts...i need something to get my block up on my engine stand...please help!
Old Jul 28, 2006 | 09:07 AM
Acura_I-RS's Avatar
Default Re: trans to engine bolts? (killerpenguin21)
go to the hardware store, and get same thread, but longer ones. thats what i did to put it on the stand..
Old Jul 28, 2006 | 09:29 AM
Default Re: trans to engine bolts? (Acura_I-RS)
well i dont raelly have a way to figure out the threads thats the issue....
Old Jul 28, 2006 | 12:08 PM
Acura_I-RS's Avatar
dont you have the bolts from your tranny? did you lose them??
Old Jul 28, 2006 | 12:19 PM
i currently own no honda. I am just beginning to build one and have a block and most bottom end parts, hence no bolts. A second trip to the dealer yielded six bolts on order that hes pretty sure are what i need...although theres 3 different size bolts? i hope hes right...otherwise im stuck with 35 bucks in useless bolts
Old Jul 28, 2006 | 12:43 PM
Acura_I-RS's Avatar
ohhhh.. well they should be an m12x1.25 fine pitch...
i beleive they are around 2-5/8" long or so, and there are 5 of them.
Old Jul 28, 2006 | 12:45 PM
Acura_I-RS's Avatar
they could be a 1.5 pitch to.. if you have the time, i would get one of each, see which fits then bring the other one back and get 4 more of the right sized..
edit---it IS a 1.25 pitch, m12 bolt, 17mm head, and around 65-70mm long. might want to get a couple slightly longer ones to mount it on the stand though.. so you dont bend the ones you are going to use to bolt it together.
Old Jul 28, 2006 | 02:43 PM
are they all the same size?
92lxsleeper
Apr 4, 2010 08:54 AM
EJ8chu
Sep 15, 2006 11:49 PM
Anthrax-VX
May 25, 2004 11:35 AM
Anthrax-VX
Apr 24, 2004 05:43 PM
