check engine light code...need help! CEL #9
Old Jul 29, 2006 | 05:31 PM
Fat Chick Magnet's Avatar
Default check engine light code...need help! CEL #9
fixed it!
Modified by dc2rtek at 10:24 AM 9/30/2006
Old Jul 29, 2006 | 10:40 PM
BluLude's Avatar
Default Re: check engine light code...need help! CEL #9 (dc2rtek)
inside the distributor, clear the code and see if it comes out again, if so replace distributor, if not...celebrate
Old Jul 30, 2006 | 12:51 AM
Default Re: check engine light code...need help! CEL #9 (BluLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BluLude &raquo;</TD></TR><TR><TD CLASS="quote">inside the distributor, clear the code and see if it comes out again, if so replace distributor, if not...celebrate</TD></TR></TABLE>
what do u mean clear the code? what the hell am i supose to do with the distributor?
Old Jul 30, 2006 | 05:08 AM
Duane_in_Japan's Avatar
replace the distributor due to the #1 cylinder sensor that went bad inside the distributor code 9, when you check for codes they clear automatically when you are finished checking on a 95 model. The light will go out after you get rid of the bad part in the distributor by changing the distributor.
Old Jul 30, 2006 | 09:06 AM
Default Re: check engine light code...need help! CEL #9 (Duane_in_Japan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">replace the distributor due to the #1 cylinder sensor that went bad inside the distributor code 9, when you check for codes they clear automatically when you are finished checking on a 95 model. The light will go out after you get rid of the bad part in the distributor by changing the distributor.</TD></TR></TABLE>
ok there is a brand new distributor on my car thats 6 months old..
Ej8 d16
Jan 23, 2015 01:37 PM
PaChiLa Leader
Oct 10, 2005 09:38 AM
ECICivic
Apr 3, 2005 04:51 PM
