will these prothane inserts fit?
i ordered a kit for my 95 teg, prothane motor mount inserts, they sent the right rear mount inserts, but sent 92-95 civic inserts for left and right? do they fit the same? there mistake? anyone know, also the rear mount has like 18mm bolt going through it, is this normally something that gives everyone a pain? it surely is about to make me go on a rampage. let me know
Hype-R Stalker
Re: will these prothane inserts fit? (twentyhurtz)
You pretty much have to tilt the engine foward as to put the rear inserts in.
The fronts are easy, so if you Have the civic inserts in hand, take one side off quick, and check.
Might take 10 minutes if that.
Re: will these prothane inserts fit? (CleanLikeJdm)
well the agrivating part about it is breaking the bolt and nut loose, its on there like king kong put it on there.
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twentyhurtz »</TD></TR><TR><TD CLASS="quote">well the agrivating part about it is breaking the bolt and nut loose, its on there like king kong put it on there.</TD></TR></TABLE>
Breaker bar yo, might need an extension.
Re: will these prothane inserts fit? (dc2go_slow)
i have this same kit. they are the same on civics and integras. i called energy suspension because i was pist. now i just want to know if they will fit in my 91 integra.
Mr.Meowsome
12-01-2006 11:27 AM
litlekikr
05-12-2003 05:30 PM
Sir_Phobos
04-03-2003 10:33 AM
