Question on clearing codes?
Old Jul 30, 2006 | 07:30 AM
JUNE_BUG's Avatar
Default Question on clearing codes?
On my 01 teg, it has a little button under the steering wheel, you hold while the key is in the on position and the code light goes away....Well my question is that I have a friend who needs to clear a code on his 94 RS DB7...And I went to it, but I couldn't find it...Does this car have one? Or is it located somewhere else? Any help would be good! Thanks!
Old Jul 30, 2006 | 07:40 AM
JUNE_BUG's Avatar
Default Re: Question on clearing codes? (JUNE_BUG)
Damn, nobody up this early in the morning!
Old Jul 30, 2006 | 08:19 AM
CleanLikeJdm's Avatar
Hype-R Stalker
The small green/teal button? It should, since I have one and it's also an obd1 car(95).
Old Jul 30, 2006 | 08:22 AM
JUNE_BUG's Avatar
Default Re: Question on clearing codes? (CleanLikeJdm)
I'll check again...could seem to find it when, I was looking for it...
Old Jul 30, 2006 | 08:27 AM
Hype-R Stalker
I thought that button was only for the "maint" light though,
which light is Actually on that you wanna shut off?
and did you try disconnected the neg battery cable for a few minutes?
Old Jul 30, 2006 | 09:21 AM
JUNE_BUG's Avatar
Yeah it's the maint. light bro... I have tried the battery cable removal, because I thought that was only to clear and reset the ECU...I might have to remove the steering colum cover/plastic whatever it's called. Maybe my fatt ****, can take a better peak! But thanks for the help bro!
Old Jul 30, 2006 | 09:36 AM
jared99's Avatar
Pull the backup radio fuse for 30 sec to reset the ecu.
ERIC1
Aug 5, 2021 04:18 AM
Karla T/
Nov 21, 2011 07:06 PM
hondamanf22
Aug 20, 2008 06:21 PM
slowcivic888
Dec 15, 2004 06:32 AM
UTKershaw
May 9, 2003 02:52 PM
