Changing fuel pump
Old Jul 29, 2006 | 05:20 AM
Joeyt426's Avatar
Default Changing fuel pump
What do I have to do to change the fuel pump in my 98 LS, take the gas tank off? Thanks
Old Jul 29, 2006 | 05:47 AM
IN VTEC's Avatar
Default Re: Changing fuel pump (Joeyt426)
No need to empty or remove the tank. You access the fuel pump through the back seat. No special tools are needed like on some makes.
Old Jul 29, 2006 | 08:09 AM
Joeyt426's Avatar
Default Re: Changing fuel pump (IN VTEC)
Is it under the back seat. What will i have to do to get to it. Thanks
Old Jul 29, 2006 | 08:25 AM
ultrablackhatch's Avatar
Take the back seat off and there will be a cover. Just remove all of the screws until you get to the pump. Make sure you disconnect the battery first. It should be pretty simple
Old Jul 29, 2006 | 08:30 AM
Joeyt426's Avatar
Default Re: Changing fuel pump (ultrablackhatch)
Alright thanks alot
Old Jul 29, 2006 | 08:36 AM
VHOA's Avatar
isn't it just the sending unit under the seat? I thought the fuel pump was in the gas tank but im use to working on older hondas like 2g tegs and 88-95 civics... i KNOW that there fuel pump is inside the tank and the sending unit is under the seat.
Old Jul 29, 2006 | 04:50 PM
jdm_bones's Avatar
Default Re: Changing fuel pump (VHOA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VHOA &raquo;</TD></TR><TR><TD CLASS="quote">isn't it just the sending unit under the seat? I thought the fuel pump was in the gas tank but im use to working on older hondas like 2g tegs and 88-95 civics... i KNOW that there fuel pump is inside the tank and the sending unit is under the seat.</TD></TR></TABLE>
The pump is still inside the tank, but you have to remove the bottom of the rear seat.. You will then find a silver cap/lid like metal piece remove that with a I think is 10mm socket...Everything is plug and play, to easy...10 min. job and your on the road again!
Old Jul 29, 2006 | 04:52 PM
jdm_bones's Avatar
Default Re: Changing fuel pump (jdm_bones)
Just make sure you disconnect the battery, and opening the gas cap helps relase pressure before you remove the lid!
Old Jul 29, 2006 | 09:33 PM
00IntegrAllmotoR's Avatar
HT Black OPs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure you disconnect the battery, and opening the gas cap helps relase pressure before you remove the lid!</TD></TR></TABLE>
said it before me.
Old Jul 31, 2006 | 10:48 AM
EM199dcs's Avatar
Default Re: Changing fuel pump (00IntegrAllmotoR)
Good advice!! Dont want any gas to spray all over ya.
Old Jul 31, 2006 | 02:09 PM
jdm_bones's Avatar
Default Re: Changing fuel pump (EM199dcs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM199dcs &raquo;</TD></TR><TR><TD CLASS="quote">
Good advice!! Dont want any gas to spray all over ya.</TD></TR></TABLE>
Thanks!
Old Jul 31, 2006 | 07:33 PM
adip315's Avatar
You also want to take the fuse out for the fuel pump, and let the engine run until it stalls. That will relieve the fuel pressure. Then disconnect the cable from the negative battery terminal.
Old Aug 1, 2006 | 12:50 PM
fatboi07's Avatar
Hey so on an 88 teg the fuel pump is in the tank?
Old Aug 1, 2006 | 01:55 PM
jared99's Avatar
Default Re: Changing fuel pump (fatboi07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adip315 &raquo;</TD></TR><TR><TD CLASS="quote">You also want to take the fuse out for the fuel pump, and let the engine run until it stalls. That will relieve the fuel pressure. Then disconnect the cable from the negative battery terminal. </TD></TR></TABLE>
Or you can take the gas cap off and loosen the banjo bolt on top of the fuel filter in the engine bay. I plugged the gas lines with golf tees since all the gas in one of the lines between the engine and the pump runs out when you disconnect the line.
black_integra
May 19, 2012 09:00 AM
tylertocker
Oct 11, 2007 09:00 PM
Toyota Guy
Jan 6, 2007 04:59 PM
white99CF
Sep 3, 2006 09:13 AM
SpeedMonkeyRacing
Nov 29, 2002 06:08 AM
