Turbo Timer Help
Old Jul 28, 2006 | 10:19 AM
Whiteintegra's Avatar
Default Turbo Timer Help
I just bought a turbo timer (greddy gtt3) and a harness that fits with it. I hooked up everthing except the parking break/speed sensor but the timer dosent turn on. Is it nessarry for me to hook the parking/speed sensor for it to turn on. I don't know if it broken or what, so im trying to try everything before i take it back. Thanks
Old Jul 28, 2006 | 10:36 AM
after i shut down the car and let it sit for a while. the turbo timer turns on for just a second and then says "off"?
Old Jul 28, 2006 | 11:33 AM
I, Just hooked up my brown wire to parking break and its still acting like it was. I dunnot what i should do? i still havent hooked up the speed sensor. But i don't think that will effect the turbo timer so im going to leave it off.
Old Jul 28, 2006 | 11:51 AM
oh, i forgot to mention, this is a gtt3 turbo timer.
Old Jul 28, 2006 | 12:31 PM
just called greddy, they said the wiring might be faulty? I dunno though. It may also be the turbo timer. Im stil waiting for one of you integra grus to chime in and shed some light on this problem.
Old Jul 28, 2006 | 06:31 PM
Default Re: Turbo Timer Help (Whiteintegra)
ok, the problem is def with the harness and the ground. I have tried it 2 different ways. Way 1.- hook up turbo timer with your harness and regular ground. Dosent work (i get power, but it give me the wierd "er.5" reading. Way2.-Hook up timer with out your harness using the same ground no problems. This leaves me to believe that there is something wrong with the harness. On a side note with the harness and the turbo timer hooked up, I seem to be getting a bad ground where ever i try to ground out too. When i hook up to a ground it turns the timer on NORMALLY for an instant, then it goes off. I have tried every ground on the driver side and with the harness installed none of them work. I then do it manually with outthe harness and and every ground works. There is something wrong with the harness. Ive also tried connecting a ground to the battery's ground and it still dosent work.
Old Jul 28, 2006 | 11:42 PM
91teggyman's Avatar
is the parking break up when u try it???
Old Jul 29, 2006 | 01:13 PM
the parking break is up, but it shouldt matter should it??!?!
Etorres325
Mar 31, 2010 05:30 PM
blinger
May 23, 2007 08:07 PM
abmerop18
Jan 13, 2005 04:20 AM
curiousgpnoy
Sep 26, 2002 05:01 PM
Ray
Jul 2, 2001 04:01 AM
