idle problem
ok i have a b18a1. the thing that is happening is the car have a rev that goes from 1000 to 2000 up and down at idle. it is like it is a idle air control valve but i have replaced it. if any buddy has an idea please help.
<U>THE MOTOR CAM OUT OF A 92 INTEGRA THAT HAD BEEN SWITCHED FROM A AUTO TO 5SPEED AND DID NOT DO BE FOR IT WAS SWITCHED TO 5SPEED!</U>
Modified by dkrex001 at 8:55 PM 7/28/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 »</TD></TR><TR><TD CLASS="quote">FITV (fast idle thermo valve) which is located under the throttle body
is that where the coolant lines go</TD></TR></TABLE>
for the b18a it is seperated and is directly inderneath the throttle body, you have to take it out, take it apart and clean it would with some some of cleaning solution
there is a write up somewhere on here about how to do it
protopro88
Apr 8, 2011 03:41 PM
