Crankshaft position code
Old Jul 27, 2006 | 11:10 AM
sohc_coupe24's Avatar
Default Crankshaft position code
I recently purchased a 97 integra ls (really cheap) for a little daily driver. However i knew that the car wasn't running right due to the fact that it studdered at higher rpms and had a rough idle. I took off the cluster and noticed that the check engine light bulb had been removed. So i plugged one in a immediately it threw a cel. I ran an obd II scanner through it and it threw a P0365 (Camshaft Position (CMP) Sensor B No Signal) code. I have searched and read that this occurs in the distributor. But i was wondering how it could be unplugged?? Thanks for the input
Old Jul 27, 2006 | 11:12 AM
lVlemphizStylez's Avatar
Default Re: Crankshaft position code (sohc_coupe24)
what do you mean by unplugged....thats one code youd have to address...try someone elses dizzy and see if the problem goes away..if it does..purchase a new dizzy...120 bucks maybe...
Old Jul 27, 2006 | 11:18 AM
woops..i meant that what does it mean that it has no signal, is there somethign missing that will cause the connection to fail???
Old Jul 27, 2006 | 11:24 AM
Default Re: (sohc_coupe24)
usually its just a faulty distributor...i couldnt tell you for sure...
Old Jul 27, 2006 | 11:51 AM
thanks for the input...i appreciate it
cityjack
Jan 7, 2015 02:51 PM
Sephrin
Nov 10, 2009 04:24 PM
PINKS
12
Jul 13, 2006 02:38 PM
Fatty_1775
Jul 25, 2003 04:52 PM
