Which ECU to use
Old Jul 1, 2013 | 08:41 PM
jonyi27's Avatar
Default Which ECU to use
I getting both side, have b20z in my obd1 integra, kept the same harness ND everything the same, just changed motor but I'm getting that I should get a crv ecu with jumper harness, others say I would be fine running my integra obd1 ecu, what's the right way? Maybe keep the integra ecu and tune it?? All opinion will be appreciated
Old Jul 1, 2013 | 08:49 PM
SpokaneSpeed's Avatar
Default Re: Which ECU to use
The P75 ECU can run the B18A/B & B20B/Z, but you won't be able to utilize the knock sensor on the engine. You'll need the B20Z ECU for this, or a P72 chipped w/ proper basemap loaded to the chip.
Old Jul 1, 2013 | 08:56 PM
jonyi27's Avatar
What would the knock sensor really do though I don't have a cel
I'm not really advanced in the ecu and it being chipped and tuned area
and a 5speed crv ecu right, just to make sure
Old Jul 1, 2013 | 08:59 PM
jonyi27's Avatar
And a p72 obd1 ecu or p72 obd2 ecu, knowing p72 is a gsr ecu
Old Jul 1, 2013 | 09:05 PM
OBD1 of course... lol. And no, you wont have a knock sensor CEL - because the ECU in your car doesn't search for it (no knock board). You're better off using the P75 that you already have.
Old Jul 1, 2013 | 09:13 PM
jonyi27's Avatar
They say since b20 is bigger then b18 the fuel ratio would be off, should I get a crv ecu and see how it acts or literally stick with my p75 and tune it later down the road
Old Jul 1, 2013 | 09:29 PM
The o2 sensor will pick up and adjust for rich/lean condition and adjust fuel parameters; the difference between these two engines is very minimal. The cylinder heads of the two engines are nearly identical. Not to mention, the B20B/Z ECU will not directly plug into your vehicle. Stick with the P75.
stenger
Engine Management and Tuning
Sep 18, 2015 08:15 PM
Freemananana
Feb 10, 2015 08:40 AM
216.226.142.95:27016
Jan 8, 2003 11:45 AM
