need vtec help
Old Jul 12, 2013 | 10:56 AM
Blake450's Avatar
Icon2 need vtec help
Hey guys i im new to this. I have a 93 ej1 civic with a 94 gsr swap. Vtec isnt wantin to work. Its all wired right. I wired the solenoid separate and it clicks. I drove it and hit the switch and still nothing. Can anyone shed light on this. My oil is good, no leaks, i just dont know qhat could be wrong. Im throwing an o2 code but that shouldnt matter. I cleared it and still nothing. Any help is appreciated.
Old Jul 12, 2013 | 12:18 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: need vtec help
um you really should get an ECU that will run that engine properly instead of hacking it with a manual switch. I'm pretty sure the ECU changes fuel maps based on whether VTEC is engaged, or if the IAB butterflies are open (and also VTEC engaged). Are you running the stock dual-runner GSR intake manifold?
Old Jul 12, 2013 | 12:38 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
do you have gsr ecu?
Old Jul 12, 2013 | 03:45 PM
B_Swapped93's Avatar
hacked swaps
get the correct ECU and wire it properly don't hack in a switch.
Old Jul 15, 2013 | 01:27 PM
Bigglesworth's Avatar
Never hack an ECU... Vtec will not work if the imput numbers from the ecu are not correct. For instance if the ecu reads that the coolant temp is too low for vtec changeover then it will not allow Vtec to engage. If the computer does not see that you turned on Vtec with a "switch" then it will not alter the fuel mapping to compensate for Vtec. Hopefully i'm making a bit of since over here
Old Jul 15, 2013 | 04:56 PM
m4xwellmurd3r's Avatar
hack job=no good
vtec has a seperate fuel map, and the gsr has dual intake runners (which really contributes the most to that tone change) otherwise youre running a big cam, on **** fuel maps. it wont make **** for power that way.
Posted from Honda-tech.com App for Android
Old Jul 15, 2013 | 05:05 PM
have you ever hit VTEC at idle ? dat toda killer cam sound doe
Old Jul 24, 2013 | 08:41 AM
Blake450's Avatar
I have a p72 in the car. Yes correct ecu. I wired the solenoid to make sure it worked i didnt hack it lol i figured out i had a vtec valve rocker pin missing ao i replaced it. My dowel on cam cap 3 was gon so i replaced it and same thing. No vtec. Im thinking ecu.
Old Jul 24, 2013 | 08:53 AM
Ferio Wdm Edition
Why didnt you do it the legit way?Correct ecu, and harness with nooo switch...
Old Jul 28, 2013 | 07:54 PM
Blake450's Avatar
It is done the right way! Correct harness p72 ect ect! I got it fixed. Thanks
Old Jul 29, 2013 | 11:50 AM
Ferio Wdm Edition
Cool, what did you change?
matt2320
25
Apr 3, 2021 03:33 AM
tgjg19
Aug 17, 2009 07:41 PM
hOndafienD 04
Jan 1, 2005 02:13 PM
nfinitecc
Nov 14, 2004 09:21 PM
311
Oct 2, 2002 04:06 AM
