Knock Sensor Troubles
Old Aug 11, 2013 | 02:19 PM
GaryTuesday's Avatar
Default Knock Sensor Troubles
I bought a 1999 GSR with P0325 (Knock Sensor malf.) CEL on and have been trying to get rid of it for months, and I need to get rid of the CEL so i can SMOG.
The light doesn't turn on right away after the computer is cleared, it stays off until 1-2 miles of driving modestly than sends P0325 CEL.
First I tried replacing the knock sensor myself which was extremely difficult without a deep socket extension, but after the replacement there was no affect on the symptoms.
Next i took it to the shop who replaced the sensor again, replaced the plug and wiring, and checked for good continuity to my ECU (an aftermarket XS Engineering ECU at the time), still nothing. The guy said its was definitely my ECU. So i ordered a OEM p72-a04 ECU, plugged it in, but it still didn't fix the light.
Now im stumped, if anyone has any idea ideas it would be greatly appreciated. I really need to fix this problem before I go to college which is coming up fast.
Old Aug 11, 2013 | 02:28 PM
jdmjunkieXL's Avatar
Default Re: Knock Sensor Troubles
Maybe your engine has a knock in it??? Have u checked ignition timing?
Old Aug 11, 2013 | 04:22 PM
Maybe, I thought it could have because on my XS Engineering ECU, theres a sticker that says for 92 octane only, but the highest i can get in my state is 91. but the code still came back with the OEM ecu. And wouldn't i be able to hear a knock just from driving it?
Old Aug 11, 2013 | 06:06 PM
CleanLikeJdm's Avatar
Hype-R Stalker
What is an "XS engineering" ecu? Just a chipped ecu with some random *** maps on it?
You also mention it's a 99, so you must have/had some sort of conversion harness right?
Old Aug 11, 2013 | 06:23 PM
Heres a pic of the ECU, I'm not sure about the harness tho, I believe its OBD2a
Old Aug 11, 2013 | 06:33 PM
Hype-R Stalker
Weird, never knew obd2 could be chipped and still don't believe they can be.
Which one does your ecu actually look like if you take the plugs out?
Old Aug 11, 2013 | 06:40 PM
OBD-2a
Its a 99 Integra GSR
Please look at these pics for reference
http://imgur.com/a/aykwH
The board with the sticker on it is the XS ECU, and the blank one is the OEM ECU.
Old Aug 13, 2013 | 12:07 PM
Bump
Anyone have any ideas? The problem is intermittent, the CEL goes away sometimes but comes back after a few minutes of driving.
Old Aug 13, 2013 | 12:09 PM
Inspect ignition timing
Old Aug 13, 2013 | 01:03 PM
Okay im gonna try to find my dad's old ignition timing gun and check it out. I suspect the timing has been advanced, so ill see whats up. Thanks for the advice.
mattsthru
13
Oct 22, 2024 06:15 PM
wade9233
Jun 26, 2013 01:25 PM
bak lee
Jul 26, 2005 08:58 AM
shatchi
17
Feb 1, 2005 10:00 AM
Thagreybomber
Sep 11, 2002 10:16 PM
