b20v help!
So I'm currently having an issue with my new build..
When i start car it has a weird 2-step idle then goes to normal rpm. When driving with foot slightly on pedal it seems to bog /cut fuel (i think) also when I reverse it does that 2-step idle thing again.. idk
does my iac have anything to do with this or ecu??? I'm using a p28 I had chipped for 1.8, now I'm running 2.0 with Stock fuel pump, injectors, fuel rail etc. Help please!!
does my iac have anything to do with this or ecu??? I'm using a p28 I had chipped for 1.8, now I'm running 2.0 with Stock fuel pump, injectors, fuel rail etc. Help please!!What you really need is get a wideband gauge to monitor your air/fuel and get it tuned.
A basemap is just for you to start it up and get it to a tuner.
I got this chipped ecu like a year ago online.. I haven't checked for any codes, I know my check engine is on for a fact because of some sensors.. people tell me check engine lights shouldn't even appear after you get a chip.. well mine does! Has anyone had similar fuel problems like this??
Fix the sensors...when you have no cel and the car is still acting weird, then come back with a real problem and state what you've done to try and correct the issue. So far you haven't done anything by the sounds of it.
You clearly said you havent checked for any codes....so you really dont know whats going on. Check the codes, takes 1 min to do.
I wasn't able to check for codes but I was able to mess around with the sensors behind the intake manifold. I switched two sensors around, the purge cut solenoid & iac.. they're identical! That seemed to do the trick
JDM_SOHC
23
Apr 18, 2005 11:55 AM
MintFlavored
Nov 3, 2002 06:57 PM
