Code 23 knock sensor help
Old Aug 6, 2013 | 08:24 PM
nicknack25's Avatar
Default Code 23 knock sensor help
I've got a gsr swap in my crx and the knock sensor code comes on randomly, but only late night when its cold. I'm wondering if it's a fault knock sensor or is my motor really knocking?
I've erased the code and held rpms between 3000-4000 for 10 seconds, but the code does not come up.
Any help would be appreciated
Old Aug 6, 2013 | 08:54 PM
B_Swapped93's Avatar
Default Re: Code 23 knock sensor help
Checked ignition timing ? have you done anything to the car recently
Old Aug 6, 2013 | 09:01 PM
nicknack25's Avatar
Yeah ignition timing is at 16 btdc and actual timing is all lined up. Haven't done anything internally to the motor yet, only plugs wires cap and rotor. And normal oil changes.
Old Aug 6, 2013 | 09:03 PM
could be the sensor it's self, only does it at night under load ? and when cold. you're using 91/93 right ?
Old Aug 6, 2013 | 09:08 PM
nicknack25's Avatar
I think the code came up once during the day but always when my car has been sitting for a while under load. And yes im running 91
Old Aug 8, 2013 | 12:52 PM
CleanLikeJdm's Avatar
Hype-R Stalker
I have two gsrs that come up with a cel for the knock sensor when warmed up.
It's not a limp mode cel, so it doesn't affect anything.
I'd just disable the sensor if you have a chipped ecu.
Old Aug 8, 2013 | 02:53 PM
nicknack25's Avatar
Yeah, mine doesn't go into limp mode either. Chipped ecu coming soon though.
jchrm80
Jun 20, 2007 08:51 PM
Bserieskllr
Sep 11, 2004 05:43 PM
handa
10
Aug 11, 2004 07:10 PM
99spanishGT
Mar 26, 2004 12:40 PM
roadawg
Feb 11, 2004 01:10 PM
