compression readings
Old Oct 29, 2007 | 07:11 AM
VTEC_PRODUCTION's Avatar
Default compression readings
does anyone know the compression specs for the 3 gen ls teg? or the parameters that it needs to be in? my car burns oil and there is some oil coming from between the head and the block so i have no idea if its a head gasket or just weak pistons...
Old Oct 29, 2007 | 09:47 AM
blueDA9's Avatar
Default Re: compression readings (VTEC_PRODUCTION)
I think 180 across the board is good.
Old Oct 29, 2007 | 09:54 AM
nate_2k5's Avatar
Default Re: compression readings (blueDA9)
it doesn't matter as much about the number as it does how far they are apart. if it is below 140 on all cylinders then i would be worried
edit: the number should not deviate 10-15% between the cylinders
Old Oct 29, 2007 | 10:00 AM
Default Re: compression readings (nate_2k5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 &raquo;</TD></TR><TR><TD CLASS="quote">it doesn't matter as much about the number as it does how far they are apart. if it is below 140 on all cylinders then i would be worried
edit: the number should not deviate 10-15% between the cylinders</TD></TR></TABLE>
well i mean it just burns oil. i know its not valve seals...some people tell me its head gasket cuz you can see oil on the block. i just think the motor is tired...is there a way i can determine this?
Old Oct 29, 2007 | 10:09 AM
nate_2k5's Avatar
compression and leakdown test and clean off the block and watch where it leaks first
Old Oct 29, 2007 | 10:46 AM
AWD Terror's Avatar
max-200psi
minimum 135psi
max variation-28psi between cylinders
Old Oct 29, 2007 | 12:24 PM
Options's Avatar
All Secrets Known
Default Re: compression readings (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">max-200psi
minimum 135psi
max variation-28psi between cylinders </TD></TR></TABLE>
Those specs are for the LS right?
Old Oct 29, 2007 | 12:33 PM
Default Re: compression readings (Options)
that is what im wondering...it is an ls engine...
Old Oct 29, 2007 | 04:24 PM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Options &raquo;</TD></TR><TR><TD CLASS="quote">
Those specs are for the LS right?</TD></TR></TABLE>
Yes.
I'm not 100% on this, but I think the GS-R is like:
max-220psi
minimum 145psi
It's not perfect, but it's close
Old Oct 29, 2007 | 04:30 PM
ok thank you
vtec_boost08
Jan 19, 2007 11:28 AM
rice a roni
May 31, 2006 07:18 PM
P@@RB@Y
Jan 20, 2006 01:19 PM
EARLdaSQUIRREL
10
Aug 8, 2003 02:43 PM
fastludeh22
May 10, 2003 08:43 AM
