quick lsv question
Old Oct 31, 2007 | 01:20 PM
pokmijn's Avatar
Default quick lsv question
I was just wondering i know i have to get new water/oil pumps since im using a b16 head do i have to get b16 water/oil pump or could it be from gsr's too.
Old Oct 31, 2007 | 01:35 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: quick lsv question (pokmijn)
You don't have to get water/oil pump to match anything,
the thing when you buy the diff water pump, is that the vtec one has a different amount of teeth.
So then you have to get the timing belt to match the pump.
Old Oct 31, 2007 | 01:39 PM
95 integra's Avatar
Default Re: quick lsv question (CleanLikeJdm)
The GSR/B16/Type R have more teeth to slow the pump due to the higher redline. Thus, its not necessarily a good thing to switch them unless you're raising your redline quite a bit (7500+ is generally the cutoff in my opinioin).
Old Oct 31, 2007 | 01:40 PM
St Jimmy's Avatar
* B A N N E D *
Check out this build
https://honda-tech.com/zerothread?id=1812388
An itr pump is pretty common for lsv setups.
Old Oct 31, 2007 | 02:33 PM
pokmijn's Avatar
Default Re: quick lsv question (St Jimmy)
thx guys i just thought that if i use a b16 head i have to get b16 pumps.
vtechjunkie
Apr 26, 2011 08:14 AM
1992db2
Jul 13, 2009 08:38 PM
1992db2
Jul 7, 2009 06:00 PM
dc2dragster
May 24, 2003 12:46 PM
02WRX
Jun 3, 2002 07:37 PM
