b18
hey guys i need some help
i have a 93 da with a b18a1 with s1 trans..its time to rebuild
i heard about b18 stroker kits for the b16
is it possoble to put b20 piston and rods in a b18 like a stroker kit
if so what all would i need and what kind of power would i get
thanks
thanks
People sell stroker kits and you can bore it out to 84mm, however the stock LS and B20 rods are the same...just the piston bore is different. Clearly probably not the best route for you currently though....stick with just a rebuild and some basic mods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror »</TD></TR><TR><TD CLASS="quote">What are your goals? WHP?
DD or track *****?</TD></TR></TABLE>
i was it for a dd..but i want some power u know..and i know im goin to have to get it sleeved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">People sell stroker kits and you can bore it out to 84mm, however the stock LS and B20 rods are the same...just the piston bore is different. Clearly probably not the best route for you currently though....stick with just a rebuild and some basic mods.</TD></TR></TABLE>
so all i realy need is b20 pistons then go get my block bored and sleeved
