Auto to Manual Conv. Help
Old Oct 30, 2007 | 07:09 PM
datflyboy's Avatar
Default Auto to Manual Conv. Help
on the clutch pedal theres 2 sensors but theres no wire for them. Where are the plugs for them? or where are the wires that im supposed to run to the sensors at?
theres a white and yellow sensor...what are they for?
Old Oct 30, 2007 | 08:49 PM
datflyboy's Avatar
bump..need to finish this conv. ASAP
Old Oct 30, 2007 | 09:09 PM
integra_661's Avatar
Default Re: (datflyboy)
i was about to post something like this i need help with this to help help help what does i need !!!!! help help no but seriously what do i need, and how much would it cost to do the conversion
Old Oct 31, 2007 | 05:13 AM
toofast4u752's Avatar
if you swaped in the pedal assembly and keeped the stock auto dash harness your no gonna have them... theres no need for them.... unless you really need your car to not start without the having the clutch pressed......
the swap isnt hard..the hard parts are intalling the pedal assembly without removing the dash and then wiring around the nuetral safety switch and getting it to think its in park... besides that its the same as changing a clutch... and the tranny mount you can use longer bolts and some shims...
those sensors you dont need...
Old Oct 31, 2007 | 07:57 AM
asr10 user's Avatar
Default Re: Auto to Manual Conv. Help (datflyboy)
clutch switch.
Old Oct 31, 2007 | 08:33 AM
shiux's Avatar
if you dont wire up those sensors, you can install a remote car starter.
Old Oct 31, 2007 | 08:37 AM
boostedh22lude1's Avatar
Default Re: (shiux)
u dont need them, but the car will start without clutch engage so be careful
Old Oct 31, 2007 | 10:04 AM
lmike6453's Avatar
Default Re: (shiux)
you can install a remote start regardless of the switch, just not legally where i live
Old Oct 31, 2007 | 10:08 AM
dizzzane's Avatar
Default Re: (lmike6453)
Its for the neutral safety switch. It just makes sure the clutch is fully depressed when the ignition is turned to ensure it doesn't lurch in gear upon start up.
Old Oct 31, 2007 | 10:25 AM
K2sInteg98's Avatar
Default Re: (dizzzane)
yeah you dont need it. its better not to have it imo. You'll appreciate it if you ever upgrade your clutch and its so hard to push.
Old Oct 31, 2007 | 12:05 PM
datflyboy's Avatar
aight cool. so..how do i get the car to think its in park? after that im done
Old Oct 31, 2007 | 12:51 PM
{Sigur-Ros}'s Avatar
[a freindly help]
BUMP
Old Oct 31, 2007 | 12:58 PM
well since i did this over 3 years ago i can remember the exact wires or nothing... but just dissassemble the shift selector and check to see which wires tell it that its in park.. then just leave those connected permanently.. then just tuck them somewhere out of the way...
Old Oct 31, 2007 | 01:45 PM
datflyboy's Avatar
so all the wires that were in the shift column area..leave those all connected but hide em?
what about the reverse light? does that work without any mods?
Old Nov 1, 2007 | 03:19 AM
datflyboy's Avatar
bump..
Old Nov 1, 2007 | 05:26 AM
oh yeah the reverse yes you do need to wire just find the two wires that turn on your reverse lights and wire them to your reverse switch on the tranny...
Old Nov 1, 2007 | 05:34 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (toofast4u752)
reverse lights aren't a big deal....unless you have to take the car in for some sort of inspection...if not, i say forget them
Old Nov 1, 2007 | 08:15 AM
AWD Terror's Avatar
Default Re: (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">reverse lights aren't a big deal....unless you have to take the car in for some sort of inspection...if not, i say forget them</TD></TR></TABLE>
Or just hook them up to a switch
Old Nov 1, 2007 | 12:04 PM
Default Re: (AWD Terror)
for the park/nuetral switch the 2 big black wires on the connector splice together and ur good.
Old Nov 1, 2007 | 06:26 PM
datflyboy's Avatar
aiight good lookin out im wire illiterate lol
Old Nov 1, 2007 | 06:28 PM
yeah so how much would this conversion cost??
Old Nov 1, 2007 | 06:45 PM
Default Re: (integra_661)
cool thanks
Old Nov 1, 2007 | 08:42 PM
datflyboy's Avatar
well its cheap for me..just gather all the parts
tranny
clutch master cyl.
slave cyl.
ecu
all 3 pedals
shift linkage
cluster
hasport auto2manual mount (thats what i used)
clutch,flywheel,press. plate
shift console
steel braided line for clutch master to slave (thats what im using)
shift fork, throwout bearing
parts cost: around $700 for everything for me
finding people who are parting out their cars is a dream come true lol. and also friends who dont need parts anymore.
Old Nov 2, 2007 | 05:21 AM
adamrich33's Avatar
or you can find a parts car and drill and cut the trans mount bracket on the car and weld into place of your car
Old Nov 2, 2007 | 05:53 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (adamrich33)
or you can buy a 5spd to begin with
