TPS Sensor?
Old Oct 28, 2007 | 08:35 AM
bvilleteggy62's Avatar
Default TPS Sensor?
My teg starts to misfire when I push down the throttle more than half way, but under that it seems to be perfectly fine. Could this be a bad tps sensor and if so would it cause a misfire? Thanks for your input
Old Oct 28, 2007 | 09:11 AM
mtber's Avatar
Default Re: TPS Sensor? (bvilleteggy62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bvilleteggy62 &raquo;</TD></TR><TR><TD CLASS="quote">My teg starts to misfire when I push down the throttle more than half way, but under that it seems to be perfectly fine. Could this be a bad tps sensor and if so would it cause a misfire? Thanks for your input</TD></TR></TABLE>
1. Read the codes on your vehicle using a paper clip & the 2 wire service connector.
(Articles listed on http://www.phearable.net/tech)
2. Diagnose the codes....
ek_chris
10
Sep 12, 2006 09:57 PM
88crxhfb16
Nov 15, 2005 12:22 PM
ndlyng
Sep 1, 2005 10:28 AM
R_type
May 25, 2005 05:55 AM
Mr.Death
Feb 6, 2005 02:30 PM
