Bizarre Idle
Old Oct 30, 2007 | 07:09 PM
drock305's Avatar
Default Bizarre Idle
A little while back my idle when the car was warming up was a little funny, and I couldnt figure out what to do. I read on-line and it said to clean my IAC Valve or something like that so I did.. it didnt fix the problem.. any ideas?
Old Oct 31, 2007 | 07:11 AM
Ithinkyourlost's Avatar
Default Re: Bizarre Idle (drock305)
Well, if the car is at running temp and the idle is fluctuating back and forth say from 1k-1.2k for instance, then your IAC valve is bad.
You can't clean and expect a broken part to be fixed. I recently cleaned my IAC and it got worse, it's old and needs to be replaced.
Old Oct 31, 2007 | 08:45 AM
Exeed's Avatar
Default Re: Bizarre Idle (Ithinkyourlost)
You should also check your vacuum hose
Old Nov 7, 2007 | 06:56 PM
drock305's Avatar
Default Re: Bizarre Idle (Exeed)
which hoses? and how do i check them?
thunderboy
Jan 27, 2008 10:24 AM
poopydx
Mar 4, 2006 01:32 PM
jaydoghondacivic25
Jan 30, 2006 09:01 PM
94SHOWLS
Feb 17, 2005 12:31 PM
4gen
Jan 11, 2004 05:28 PM
