need help!!!
Old Oct 30, 2007 | 06:42 PM
sittin_sideways's Avatar
Default need help!!!
i have 95 gsr w/jdm itr swap i have new plugs and wires, new dissy, new timming belt. and have been having problems getting the car to start its getting fire and fuel. now it is making alot of noise around the fuse box under the hood, frying noise under the dash, and tac jumps around, and cel light is very dim, i cant check for cel codes, with the key on. no melting or burning smell, everything was working fine, but wouldnt start, then it just started doing this
Old Oct 30, 2007 | 08:18 PM
nate_2k5's Avatar
Default Re: need help!!! (sittin_sideways)
sounds like a bad ground
Old Oct 31, 2007 | 05:46 AM
integtegluver's Avatar
check ur ground wires my friend had the same problem with the lights and startin problem easy fix if thats the problem
Old Oct 31, 2007 | 05:51 AM
Duane_in_Japan's Avatar
Default Re: need help!!! (integtegluver)
ECU turns on the CEL throught power given by the main relay BUT the ground is at the thermostat housing probably like most Honda ECU grounds, I seen the dim CEL before and the ground was the fix. Wire brush it and put it back on.
Old Oct 31, 2007 | 12:40 PM
redone the ground on trans and cleaned the ground on thermo housing
Old Oct 31, 2007 | 02:22 PM
checked the groungs fixed the noise and dim lights now it will not start, so i pilled the fuel rail and i think two of my injectors are gummed up, i know alot of injectors can be hooked to a aaa battery and they will open and close are honda injectors the same way?
Old Oct 31, 2007 | 08:05 PM
Default Re: (sittin_sideways)
Glad that part was good, please reverify spark and fuel, for sure now, I recommend buying one of those adjustable spark testers.
Old Nov 1, 2007 | 04:29 PM
found what i think may be the problem pulled the fuel rail and two injectors had fuel in the tip and two didnt think they might be gummed up ill be pulling them and cleaning them in the next few days
rlyn09
Nov 24, 2017 01:45 AM
miguey310
Sep 13, 2011 07:55 PM
Track Beast
Dec 5, 2010 01:04 PM
floored4door
72
Jan 14, 2010 06:19 PM
iixerOii
Jun 8, 2004 03:18 AM
