b16 ecu
Old Oct 30, 2007 | 07:30 PM
serr38's Avatar
Default b16 ecu
so my buddy told me that whip factory told him that if he puts a b16 ecu on his dc2 gsr that it will help powerwise and such, is this right
Old Oct 30, 2007 | 08:21 PM
dcRay's Avatar
Default Re: b16 ecu (serr38)
They gotta to be kidding.
Old Oct 30, 2007 | 09:57 PM
Jtuned DC2's Avatar
* B A N N E D *
Hell no. And We all know your are trying to do this to your GS-R.. dont do it.
Old Oct 30, 2007 | 11:19 PM
iH8RICERZ's Avatar
the b16 ecu is meant to run the 1.6L dohc vtec engine, unless it has been chipped and tuned to run for any other dohc vtec engine. It also doesnt look for the iabs, which the stock gsr intake manifold has. If you run a b16 ecu into a gsr, you basically lose the midrange power and will not make any power overall.
Old Oct 31, 2007 | 06:12 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by serr38 &raquo;</TD></TR><TR><TD CLASS="quote">so my buddy told me that whip factory told him that if he puts a b16 ecu on his dc2 gsr that it will help powerwise and such, is this right</TD></TR></TABLE>
your "buddy" heard no such thing....this is false
Old Oct 31, 2007 | 06:17 AM
dizzzane's Avatar
Default Re: b16 ecu (GRAF-FITI)
Although you guys are right in that the p28 won't detect the IABs, the fact that it is meant to run a 1.6L means nothing. I used a totally stock p28 ECU on my 98 type R engine and it ran awesome, put down 184 whp with an LS 58mm TB and minor bolt ons I/H/E.
Old Oct 31, 2007 | 06:19 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: b16 ecu (dizzzane)
not saying it won't work....just saying it won't IMPROVE performance/power as the OP thinks
Old Oct 31, 2007 | 06:53 AM
Rickdrizzle's Avatar
maybe it'll run better if the gsr had a single stage runner.
dizzzane's Avatar
Oh I agree, it won't work well for the GSR.
Old Oct 31, 2007 | 08:38 AM
iH8RICERZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzzane &raquo;</TD></TR><TR><TD CLASS="quote">Although you guys are right in that the p28 won't detect the IABs, the fact that it is meant to run a 1.6L means nothing. I used a totally stock p28 ECU on my 98 type R engine and it ran awesome, put down 184 whp with an LS 58mm TB and minor bolt ons I/H/E. </TD></TR></TABLE>
Not a very smart move to run a virgin p28 ecu on a dohc vtec motor. You run a very high chance of running lean and blowing your motor. If the p28 was chipped, then tuned for your motor, then thats a different story. BTW, the stock obd1 b16a ecu is a p30 out of a 94-95 del sol and/or pr3 out of the 92-93 jdm integra xsi. I believe the newer SI's used a p2t ecu. Basically, tell your friend to stick with his stock gsr ecu unless his motor is built, then running a chipped ecu tuned for the set up is the most ideal way to go.
Old Oct 31, 2007 | 08:41 AM
boostedh22lude1's Avatar
Default Re: b16 ecu (iH8RICERZ)
wil not make any more power un chiped
Old Oct 31, 2007 | 09:56 AM
dizzzane's Avatar
Default Re: b16 ecu (boostedh22lude1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">
Not a very smart move to run a virgin p28 ecu on a dohc vtec motor. You run a very high chance of running lean and blowing your motor. If the p28 was chipped, then tuned for your motor, then thats a different story. BTW, the stock obd1 b16a ecu is a p30 out of a 94-95 del sol and/or pr3 out of the 92-93 jdm integra xsi. I believe the newer SI's used a p2t ecu. Basically, tell your friend to stick with his stock gsr ecu unless his motor is built, then running a chipped ecu tuned for the set up is the most ideal way to go.</TD></TR></TABLE>
Had the engine running fine for a year and a half..... and the ECU was a p28
Old Oct 31, 2007 | 10:30 AM
iH8RICERZ's Avatar
Had the engine running fine for a year and a half..... and the ECU was a p28</TD></TR></TABLE>
stock/virgin p28 ecu?
Old Nov 5, 2007 | 08:15 PM
serr38's Avatar
thats all i heard from him i told him he was stupid and but then again idk thats y i asked lol
dev203d
Engine Management and Tuning
17
Feb 24, 2011 01:24 PM
T"u"Rtle
Oct 7, 2005 12:11 PM
matto2413
May 11, 2005 03:57 AM
matto2413
May 10, 2005 01:27 PM
Phatch99
Jul 6, 2004 11:22 AM
